Hi Guys,
What I am looking to do is, use something like a short length of toaster wire connected to a power source. The length of wire will be about 2cm long and bent into almost a complete circle.
What it will be used for, is a piece of nylon will be run through that loop, and using a remote control I can apply the power to the circuit, the wire will get hot and "cut" the nylon string. think of it as a anti-snag device.
the problem I think I may have is, I only have 12 volts DC power supply (7.2A/H SLA battery). Does anyone know if that will get toaster wire hot enough? I assume the average kitchen toaster is not transforming the voltage or stepping it down, can anyone give me some advice on this? I would of just tested it but I don't have any nichrome lying around.
