Hi Ante, Alun
Melting point for aluminium is around 660C. I don't know what the temperature should be for pouring into the mould ???, when I was working in the foundry we knew it was at the right temperature, by its texture and colour and it was very rare that we ever got it wrong, hopefully I still have that ability 8).
This is the most common method for a backyarder to use as a mould, green sand (http://www.backyardmetalcasting.com/book_sc.html) and this is the method that I'll be using to begin with, there are many other methods as well for example, the loss foam method and dry sand.
The time it takes to melt the aluminium, is about 2 to 3 hours, each melt after that takes about 30 to 45 minutes roughly,
High-powered heaters, will help to a certain point, that is to reduce the time it takes to raise the furnace temperature up to its maximum temperature, which is governed by the maximum temperature the elements can handle which is 1200C, for the elements that I'm using, Nichrome 80.
So now it looks like I'm going to have to maintain a constant temperature in the furnace, if I want to avoid the temperature rising above that of which the elements can handle and to help them last as long as possible. I was really hoping that I wouldn't have to do this, man nothing is simple is it.
Ok, I can get a K type Thermocouple that is rated to over 1200C, for 13.00$ that is meant to be used with a DMM, that I think should do the job. Next I will need a Thermocouple Preamp, I have been searching the net for a circuit, that uses commonly available components, I haven't had any luck yet. I already have a LCD digital panel meter, that I could use to monitor the temperature, once I get that sorted out I don't know what to do, that is how to connect it to my existing temperature control circuit? Maybe I could connect a relay between the DIAC and the gate of the TRIAC, to switch the power on and off to the elements, this might be the simplest way for me to do it, but I would much prefer to be able to have the output from the temperature sensor, to very the power to the elements to maintain a preset temperature, I will also have to be able to set a maximum, as I do now or the elements will burnout straightaway.
Any help please, I don't really know what I'm doing, this project is beginning to become more complicated than I expected
