Making an electric furnace.
ante1
Jan 24, 2004
4,138
Alun,
Why to you think a picnic thermos flask is shiny inside? 8) The shiny side of a foil will reflect light and heat; this is why I want the shiny side inwards to keep the heat in the furnace. Light and heat are radiation just with different wavelengths. This is used in space to protect satellites and spacecrafts from heat and radiation (often using gold foil). And here on the ground or almost on the ground we use it in our shoes on insulating soles to reflect back the heat to the underside of our feet. And it
Alun
Alun,
I bet it's more shiny on the vacuum side (the part you don't see)
This is a common misconception as I said the foil's in contact with the furnace, thus it can't reflect any heat, so the heat is immediately conducted to it. Try this, hold an open biscuit tin up to your face and will feel warm because the shiny reflective surface on the tin is reflecting your body heat back at you, but if you touch the tin it will feel cold.
Yes, it works both ways.
Alun
Try this, it's not a very good linear ramp generator it will just output a voltage wave form of 16 steps - more than adequate for this application.
Dazza
Jun 21, 2004
591
Hi Ante, Alum,
Ante, sure I like the idea, but it's the putting it all together I'm not too sure about, by the time I'm finished that is if I can work out where to start or how to start, I should be able to pick up satellite TV with it, the way things are going ;D.
Alum, Sorry my electronic knowledge is very limited :-\, I don't understand the circuit you have provided or how to use it, I understand it is for creating a slow rise and fall response to the elements ???.
Dazza
Jun 21, 2004
591
Yes Ante :), amplify the voltage to the correct level, to display the temperature on to my 3.5 LCD panel Meter, then I can work on the inverting amplifier to drive the LED, then look at what else can be done ones that is working correctly :D.
I can borrow a thermometer from my neighbour that he uses for his homebrew, its maximum temperature read out isn't very high, but it should be enough to get a fairly accurate idea of what my thermocouple voltage output represents.
I will post the results tonight :D.
Alun
Hi Dazza,
By the way it's Alun not Alum :D
The circuit I've posted is a 4 bit binary counter with a poor man's analogue to ditital converter on the output.
the circuit counts from binary 0000 to 1111 thus connecting resistors on the A B C D outputs in various combinations these in turn form a potential divider with the 1K connected to ground.
The counter is counts a stream of pulses on the clock pin I've not shown it here but when the counter reaches 1111 it needs to stop or it will keep generating the ramps every 16 clock cycles.
I would connect this to the burst control unit. This will then turn the power up slowly. Then you use switch control to turn the furnace off when it gets too hot and back on again when it's too cold. Suppose you set the turn on temperature to 750
Dazza
Jun 21, 2004
591
Hi Ante, (Alun ;D)
Ante, here are the results of comparing the thermocouple voltage output to the thermometer. There is quite a difference between the temperature of the Molten aluminium and from where I measured the temperature of the furnace. I think I should be able to use the 200mV range of my 3.5 digital panel Meter, to represent the temperature. Ok 18.8mV = 560 so 188mV as it would be seen with out the decimal point on my digital panel Meter, times it by 3 A gained of 3 = 564mV, so what value resistors should I use for R2 and R1. Also I should be able to use the second amplifier of the TL 061 as an inverted amplifier to drive the LED? Amateur I M does it show ::) ;D.
18.8mV = 560C air temperature inside furnace.
25.2mV = 780C temperature of Molten aluminium.
200C = 07.3mV
190C = 07.0mV
180C = 06.6mV
170C = 06.1mV
160C = 05.6mV
150C = 05.1mV
140C = 04.7mV
130C = 04.2mV
120C = 03.7mV
110C = 03.3mV
100C = 02.8mV
90C = 02.4mV
80C = 01.9mV
70C = 01.6mV
Thanks Alun, I understand much better now how it works. You still want me to go with your idea, of the on-off switching, very persistent aren't you ;D ;D. I helped my neighbour lay a few slabs of concrete, I told him that he needs to soak the ground before pouring the concrete, as the ground is very dry and it will draw the water from the concrete very quickly and it will crack, he just wouldn't have it, and sure enough it cracked ::), man I was very persistent as I can be ;D, and he was starting to get very annoyed with me >:(, he has moved house now not because of me, we are still good mates, last week I went for a visit and he had laid a slab of concrete leading from the front of his house, yet again he still didn't soak the ground first and it was full of cracks, he believed that it would be sufficient to occasionally hose down the concrete, sometimes there is just no changing someone's mind ;D.
I'm sticking with the way I am going with the temperature control, but you have convinced me that your way will work fine ;), once I have got everything set up for my foundry, I want to build a small furnace that is capable of casting a large heat sink or a good size project box, and offer it as a project in the project section 8), that is if mixos wants it there. So when the time comes I would greatly appreciate your help in setting up the temperature control, your way ;D ;D.
Alun
It's like when my boss at work told me to cover a table in a very thick coat of varnish. I told them it would better to use 3 thin coatings and one thick coat would take weeks to dry and look awful. But he insisted I used one thick layer and it would take too long to do 3 coatings. So I did as I was told and applied the thickest layer possible and it took more than a week to dry and looked terrible he was not amused.
Anyway Dazza, your results seem to be very linear and go up by approximately 0.35mV per 10
ante1
Jan 24, 2004
4,138
Hi Dazza,
If you set up the op-amp to a gain of 3 your display will show 56.4mV at 560C. Of curse you can
Dazza
Jun 21, 2004
591
Hi Ante, Alun
Thanks for your help, its greatly appreciated :). I shouldn't have too many problems getting this project to work now 8).
Ante, I was thinking there was two opamps in the one package, but of course there isn't ::), so I will have to use another opamp to drive the LED to influence the LDR.
I have been busy setting up the rest of the equipment I will need for the foundry, it's coming along nicely with the exception of obtaining a product called (Bentone) >:( which is an ingredient used in high-quality moulding sand. I have done a test casting using (green sand) which is a very basic moulding sand, and I'm not happy with the results :(, so I need to use a better quality moulding sand which is called K-Bond or O-Bond, which contains the Bentone.
I have come up with a few product ideas, that I can apply electronics and aluminium casting to, to produce a product I can market locally :D.
I now have to get my foundry set up, and produce a marketable product as quick as possible :eek:, to produce some extra income, as we have recently found out that there will soon be a new member to the family :D 8) 8).
Here are some smiley faces to show how excited and happy I am.
[move]8) :D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D :D[/move]
[move];D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D[/move]
Dazza
Jun 21, 2004
591
Hi Ante,
I will post some pic soon, of my test casting, the mould/pattern I used and what I have put together so far of the foundry set up :). But there will be no pic's of the new family member project ;D ;D ;D.
I have also been trying to finish off some of my unfinished projects, I have got a few of them laying around ;D.
Oh yes don't forget the hydrogen project, this is a project I will continue on with until I succeed 8), this is one of the reasons why I'm setting up the foundry, once the foundry project is making me some money, I will move on to making a metal turning lathe, then I will be in a better position to continue on with my hydrogen project.
Progress on my hydrogen project may slow down from time to time, but it will continue ;).
Dazza
Jun 21, 2004
591
Ante, here are the pic's as requested, and I'm very happy to take the opportunity to show off my work. As this was my first test casting I wasn't expecting very good results, the whole process went well with the exception of the casting sand being too coarse, resulting in a very rough surface finish which I was expecting, although it was much worse than I thought it would be, hence my quest for obtaining Bentone to be able to make a better quality casting sand.
Please do ask questions if there is anyone that is interested in this process, and I will be happy to answer any questions if I can.
Ok, a quick run through of the pic's, first up is the flask #1 consisting of the cope and drag, top and bottom half containing the sand and the mold cavity, unfortunately I didn't take any pic's when I created the mold cavity, but I will on my next casting if someone requests it. Next my furnace and my pooch #2. Then my work bench #3 for creating the mold not yet complete but still functional/usable. Next is the molding sand #4 contained within the half drum which makes up the top part of the molding bench. Then is the mold #5 that is made from MDF wasn't quite as difficult to make as I expected but still rather tricky, it has been coded with acrylic paint to prevent water damage from the molding sand. Next is a pic of the flask before casting #6. Ah then the pouring of the Molten aluminium into the mold #7. Then #8, after the poor. Then "lookout" #9 it seem to of worked, the surface finish was much coarser than expected as mentioned above but at least nothing else went wrong. Last of all #10 is the finished product, which is the Chinese symbol for (tranquillity) with the riser and filler still attached.
I should mentioned that pic number 6,7and 8 was taking using nightvision with my camera, pic number seven looks as though the Molten aluminium is white hot, "it is not" to describe its actual colour is more like a brighter orange.
MP1
Dec 7, 2003
3,399
Wow! The casting of the dog looks almost like a real one!! ;D
(Just joking) ;D ;D
Dazza, looks like you have had quite a success with this project. Perhaps you could put it together in a "How To" form and Mixos could publish it on the site.
Good Work!
MP
Dazza
Jun 21, 2004
591
Hi MP,
Don't you think it looks more like a rabbit on a surfboard when it is turned upside down ;D, that's what I refer to it as (the surfing bunny) ;D ;D
It would give me a real kick to have my project published on this site :D, and I will put together a "How To" form, once I have successfully completed my foundry setup, and I am confident in all aspects of this process, so as I can be confident that I am not misinforming anyone, who wishes to take on this project ;).
Thanks for the thumbs up MP :).
rybitski
Jan 9, 2006
161
besides using electricity, what would be the cheapest and easiest way to heat a furnace. I am interested in making a furnace of my own... Looking for guidance
ante1
Jan 24, 2004
4,138
Hi Chris,
I believe the cheapest way might be using a coal fire with a blower like a blacksmith.
rybitski
Jan 9, 2006
161
How much blowing is needed? Can you have too much 'blowing'? I'm thinking a leaf blower...
