Making anti-static carpet spray?
Rich Grise
Thanks.
Downy "Free and Sensitive" fabric softener is odorless, but the bottle says,
"Do not mix with water and store." Hmmm...
That's OK; when you premix it to put in your antistatic bottle, you're not
"storing" it, it's in use as your antistatic spray bottle contents.
Problem solved! ;-)
Cheers!
Rich
Brian
Lee said:
Mike.... yes, and salt is a powerful corrosive and I'm surprised that
someone hasn't jumped in and commented on the folly of spraying salty mist
in a computer room full of electronics!
Regards
Lee in Toronto
Inviato da X-Privat.Org - Registrazione gratuita
http://www.x-privat.org/join.php
We had our offices made with esd carpeting. Thats always an idea.
Bill Beaty
mc said:
Do people agree, then, that fabric softener is the right stuff to use?
Spray some WD-40 around? Coat your entire carpet with vegetable
oil? (Eww.)
Those "anti-static sheets" used in clothes dryers are not based on
conductivity, instead they give your clothes a molecule-thin coating
of oil. Then, when the clothes rub together, it's an oil-on-oil
contact.
"Electrification by contact" requires dissimilar substances, therefore
very little charge-separation occurs with slightly-oily surfaces.
((((((((((((((((((((((( ( ( (o) ) ) )))))))))))))))))))))))
William J. Beaty Research Engineer
[email protected] UW Chem Dept, Bagley Hall RM74
[email protected] Box 351700, Seattle, WA 98195-1700
ph425-222-5066 http//staff.washington.edu/wbeaty/
K
Kevin G. Rhoads
I've tried adding fabric
softener but it's too strongly scented to use this way.
Did you try Downy free & clear -- no stinkum in it.
mc
I think it's the one that says "Don't mix with water and store," leading me
to wonder what's going on.
Rich Webb
Guessing but once sufficiently diluted, the anti-microbial/anti-fungal
concentration probably drops below a threshold level and it can "spoil"
(grow mold, smell funky, etc.) Probably possible to keep a batch of the
diluted solution in the refrigerator. If you have access to one of those
kitchen vacuum units (FoodSaver or similar), dump the extra in a Mason
jar and evacuate it before storing.
