Marcraft SE-1016 datasheet or manual needed
rckitmaker
Jan 11, 2023
13
I have acquired a vintage Marcraft SE-1016 kit, it is missing the instructions for what components to install, the silkscreen on the board only says R1, R2... The list that links the values of the components to the callouts is missing. Googling has only led to old ebay listing of sales of the same kit, but no luck on the documents. I believe originally a workbook would guide the build first on a bradbord then installed on the PCB. Hopeing anyone has some in site to vintage documentation. The attached image is for a transistor radio kit by Marcraft I think the book for SE-1016 would be similar looking, but I am hitting dead ends on my googleing.
rckitmaker
Jan 11, 2023
13
As it is a RC kit, perhaps a RC forum might help:
Bertus
Yes this is an electronic kit that makes an R/C car. But in the world between R/C cars and electronic kits, I felt this on landed more on the electronic hobbies world. Reading the other Marcraft kit instruction books (like the one for the transistor radio), the first step would be to populate a breadboard and make observation about how the circuits work. The final step it to build the car (and to be fair it would be a sub-par RC car). The fun will be in seeing how the circuits work, populating the PCB and seeing it work. The image attached (from the radio kit) is what the "car" would look like. Thanks for the link, I will try that forum also.
kellys_eye
Jun 25, 2010
6,512
On the antiques radio forum there is an image of the complete kit showing the components mounted on a cardboard strip - does that strip still exist and, if so, does it show any markings on it?
Alternatively, post the schematic you have and a list of all the parts and we can, by process of elimination, populate the board.
rckitmaker
Jan 11, 2023
13
I found an image of the manual, the cover is yellow not red. looks like it was sold on ebay at some point.
  • vintage-marcraft-se-1016-c-sports-car_1_9eb058279913c2a3f9b97d9b0bedcf40.jpg
rckitmaker
Jan 11, 2023
13
all the parts are there, they are only labeled with the values (100 ohm, 1K ...) on the breadboard and PCB they are labeled R1, R2, C1, C2 ... The list that links component value to PCB lable is missing.
kellys_eye
Jun 25, 2010
6,512
Yes, but, armed with the component values AND the schematic we're quite good at figuring out what goes where so post them up and let us have a shot!
It may even be that the components are in order of insertion i.e. first on the card is R1, second is R2 etc - we'll easily figure this out with the details I've requested of you.
rckitmaker
Jan 11, 2023
13
sounds like a plan, i'll document what I have and post it. and we can see where it goes from there.
rckitmaker
Jan 11, 2023
13
Attached are all the parts in the order they are on the cardboard along with the PCBs (top and bottom).
rckitmaker
Jan 11, 2023
13
And here are the schematics.
rckitmaker
Jan 11, 2023
13
Update.
Attached is an image of the car body showing the connections to the steering and drive motor. I have confirmed that the color coding on the wires matches the schematic call-outs, so I know the link between the holes with letters and what wire to connect.
I found an error in the parts sheet 3, I ploaded earler, I had missed counted some transistors.
And lastly, I recreated the PCB silk screen for both PCBs so it is legible.
I am still working on what parts go ware, I found on antique radio forum someone posted a parts list (that links the R1, R2... to X ohms, y ohms...) for a Marcraft radio kit, the problem I see is that that list shows that the order of components on the cardboard do not necessarily follow the order of PCB call-outs (R1, R2...). So I don't know if I can rely on assuming that components follow a pattern.
rckitmaker
Jan 11, 2023
13
Update.
Doing my best to identify the transistors, I have identified the P-type and N-type. One interesting thing, the data sheet I found say all the transistors are 1675890326109.png, but when I compare the schematic to the PCB and follow the traces the silk screen appears to be flipped. The flat side on the silkscreen is on the wrong side. unless this means the transistor was meant to be mounted on the bottom , but that does not make sense as soldering would be difficult.1675890633848.png
rckitmaker
Jan 11, 2023
13
Doing my best to identify the transistors, I have identified the P-type and N-type. One interesting thing, the data sheet I found say all the transistors are View attachment 57935, but when I compare the schematic to the PCB and follow the traces the silk screen appears to be flipped. The flat side on the silkscreen is on the wrong side. unless this means the transistor was meant to be mounted on the bottom , but that does not make sense as soldering would be difficult.View attachment 57936
I am still having no luck finding anyone who has seen the Knowledge Transfer Project Book (KTPB). I have even reached out to several sellers on Ebay that were selling copies of the Marcraft Radio KTPB. They are checking their collocations of manuals to see if they have them, so far the best I found was one seller who has the same kit I do, but also only has the schematics.
Tweedie2014
Nov 16, 2024
3
Hello, I am having the same problem with you but with the model SE-1030. Have you made any progress or did you give up?
rckitmaker
Jan 11, 2023
13
I have still made no more progress, have not given up, just on the back burner. I have active Ebay filters to alert me when ever a related listing pop up. In the past I was able to get some of the above findings by reaching out to sellers and they were willing to send me scans of what they had. Unfortunately no one has the actual book i am looking for.
Tweedie2014
Nov 16, 2024
3
Good News! I found a way to get the manuals. I emailed [email protected] asking for the manuel for my kit and after a few days they sent me a pdf! Just make sure you specify the model and you should be good. I hope this helps!
rckitmaker
Jan 11, 2023
13
Thanks for the idea, glad you got your manual, I reached out and they responded that my kit is very old and they may not have it but would take a look, so fingers crossed.
14,317
No, it isn't. Note that this view
1737010211581.pngis from the bottom of the transistor, whereas this view
is from the top. When you rotate and flip the first image, bot images match:
