Abstract Dissonance
- Jan 1, 1970
- 0
I was thinking the other day about how to increase the usage of an ADC and I
came up with this idea. It is mathematically solid but I have no idea if it
is practical.
The idea is to use the fact that a shift in the frequency domain is
equivilent to multiplying by exp(+-I*a*t) in the time domain.
So by using that property we can shift the higher frequencies of the
function into a lower region that can be handled by the ADC. Sampling rate
can be increased by running ADC's in parallel.
To do this requres one to first compute the signal,
s_k(t) = [exp(I*k*O*t)*s(t)] ** [O/sqrt(2*Pi)*exp(I*(a +
O/2)*t)*sinc(O/2*t)]
where ** means convolution and [a,O] represents the interval of the
bandwidth of the ADC. (a represents the lowest frequency and O the highest)
So one would take k = 0 and pass it to one ADC, k = 1 to another, etc and
then to get the original signal back one just as to compute in the digital
domain,
s(t) = sum(exp(-I*k*O*t)*s_k(t),k=-oo..oo).
Thats basically it. The theory is very simple.
The hard part come with implementing it. First off, the circuitry that
actually computes the convolution and does the multiplication would have to
have enough bandwidth not to destory the signal and the time delay would
have to be taken into account. Theres also the issue with generating the
sin and cos waves to use in the exp() factors along with the sinc function.
the formula for s_k(t) does not involve information about s(t) except at the
point t so it is causal.
Certain approximations will, ofcourse, come into play like having to
restrict the convolution to a finite range(which will in effect make the
filtering non-ideal...which might be able to be taken care of after
conversion).
All this rests on how hard it is to implement the operational circuitry to
do the "shifting". Mathematically its easily provable that it works but
implementing the necessarily mathematical operations might be impossible
with circuits or might not be practical enough. (although I'm still
varifying the mathematics and making sure some things are correct)
If one can create a operational circuit that can do the above equation for
s_k(t) that can "out perform" the ADC(i.e., that it can compute s_k(t) that
will be good enough for the ADC). Then maybe we can try to impelement it and
see how well it works.
Overall it might be easier just to make a better ADC than the method I'm
proposing but thats why I'm asking since I don't have much experience with
implementing analog mathematics.
Jon
is practical.
domain,
conversion).
Jon
