MF/HF marine radio
cmutai
May 21, 2023
What is the solution to a marine mf/hf radio when the ptt is press it warns that tjhe antenna unit not responding, please verify connection. Thank yo.
bertus
3,875
What is the make and model of the radio?
What does the manual tell you about the failure?
Bertus
danadak
Feb 19, 2021
1,103
Good chance radio is seeing high SWR out of spec, something has changed on
antenna feed or driven element connections or cable short or....
Regards, Dana.
14,486
Regards, Dana.
exactly, probably going into a low poer TX or shutting down the TX completely so that it doesnt get damaged
So, @cmutai ... the solution is probably simple , check your antenna and coax feed for problems
You could also get a 50Ohm dummy load capable of the power output rating of the transmitter
and see if you still get a warning transmitting into a good load
kellys_eye
Jun 25, 2010
6,512
Could be a 'comms' issue 'tween tx and ATU. Many manufaturers use a multi-core as well as the RF coaxial feed. The multi-core can be a full comms path (send/receive) or a simpler relay selection signal with VSWR 'error feedback'. This is why we need to know make/manufacture as there can be multiple reaons for an 'error'. Using Occams Razor I agree with the above though - probably something as simple as the antenna wire fallen off the coupler!
