Hi all,
I need to understand micro I/o lines for a PIC 18F.
If I put a 10k pull up on a pin, and configure the pin as a input. It will read high. But if the same pin is set to an output, what happens? Also can I drive this low even though it has a pull up, by this I mean using the internal FET or open collector transistor inside the micro?
Best regards
Raj
Best regards
Raj
