Micro wind turbine
Waco Bill
Jun 7, 2016
I have a AC 3 phase .1-1.0 amp 3v-24v generator turned by a 15 inch propeller. I have been using it to light up LEDS....a light up back-yard whirly-gig. My LEDS (10mm 30000 MCD) burn out after about a couple of hours of good wind. Electrical output varies with the wind. My question is...what type of diode do I need to keep the LED bulbs from burning out?
you need to limit the maximum current which can flow through the LEDs.
If they are high power LEDs (1W and above) then you will also need a heat sink to prevent them from getting too hot even at the normal operating current.
If you look at our resource on LEDs you will find a simple constant current circuit that you could use.
oh, you also need to protect the LEDs from reverse voltage. Are you rectifying the output of your generator?
Waco Bill
Jun 7, 2016
Sorry Im ignorant when it comes to electronics but I trying to learn. Ive had the generator wired directly to the LED is a10mm 30000 MCD. Trying to keep it simple....I thin I may need abridge rectifier?
a bridge rectifier would be a good start.
however, also check the maximum current for the LED. It's likely to be way less than 1A.
Thanks Bob, I wrote the above and failed to post it. Your answer may be better :)
