partyanimallighting
- Oct 22, 2012
- 331
- Joined
- Oct 22, 2012
- Messages
- 331
Hi wizards, I'm trying to resolve some problems I'm having with some olddd Martin MX-4 scanners. I'm having some problems with 2 of the 4 units that I use. I removed all the ULN2803 drivers from the pcb's of all 4 units and installed IC sockets on all the pcb's so that I can swap around the 2803's between pcb's to find the faulty drivers, my simple troubleshooting method. I can now replace any defective drivers easily from the pcb's whereas before they were all soldered in, and by swapping around, I've discovered that 5 of the 12 drivers on the 4 pcb's were defective and have to be replaced. However, on 2 of the pcb's, I'm still getting an issue with color on one and shutter on the other so I'm assuming that the AT90S8515 microcontroller is faulty. When another pcb is installed the units in question function properly so it's definitely not a motor or motor harness problem.I've found the schematic for the pcb and it's attached. Here's my question....I've searched online and found the Atmel AT90S8515 microcontroller and ULN2803 drivers. Can I simply purchase these parts and replace them in the defective pcb's or do these drivers and microcontrollers have to be programmed to suit the pcb's?
