[email protected]
- Jan 1, 1970
- 0
Somebody is going to have to explain page 3 of this data sheet to me.
Please don't tell me it is a misprint, as National has had six years to
correct.
At a supply voltage of 15 volts, the curve shows 10 watts out.
Last I looked no single-supply design can drive to below zero or above
supply rail without the use of some inductive tricks that the test circuit
doesn't show.
So, converting a 15 volt peak-to-peak output signal (assuming that the
device can swing to both rails) gives about 5.3 volts RMS.
The data sheet specifies an 8 ohm load, so given that Power = volts^2 / load
yields about 3.5 watts out.
What gives?
Jim
Only thing I can think of - they're assuming (-15V) and (+15V)
available.
If you go from 0-15V, you're right;
15 / SQRT(2) / 2 = 5.3V RMS; V^2/R = 3.5 W.
If we go (-15) to (+15), we take
30 / sqrt(2) / 2 = 10.6V; (10.6V)^2 / 8 ohm = 14 W out possible. With
some going to heat.
Michael
