Mini Quadcopter As a web camera or FPV
Creative_Maker
Jun 30, 2023
8
Hello Everyone, Nice to join you'll here. I was trying if mini ready to fly quadcopter can be used a web camera or FPV
So far i tired to use the usb cable attached to the mini quad with the laptop.
Tried to update driver, hardware setting, etc.. nothing working.
On the laptop when i go into the camera and the select change camera option i only get dark blank screen ?
No able to view it ? possible to make it work ? what is the tech issue..
Any one can please suggest...
Delta Prime
Jul 29, 2020
2,996
For data transfer through USB cable to the laptop you must have a fully charged battery in your quadcopter and you must turn the drone on. Make, model of your quad.
Creative_Maker
Jun 30, 2023
8
Sorry but i am just trying to use it a usb web camera . battery is full charged ..the quad light blinks when the transmitter button is pressed. tried it with micro SD card inserted and without it also ..The image is saved in the SD card as normal...but no live vide0 feed on the laptop...
its hubsan x4 h107c+
Have you read and understood the manual...??
https://www.bhphotovideo.com/lit_files/134120.pdf
Alec_t
Jul 7, 2015
3,821
There's nothing in the manual in the post #4 link to suggest that camera images can be sent any where except to the SD card.
Creative_Maker
Jun 30, 2023
8
Mostly probably i tried few other thing.but not working. Few years back i just found some app which help you to convert mini quad into F.P.V camera .etc...just need to install app on SD card.. but can't find the app ...:)
any other possible way to make it work or app ?
yes....thanks..
Well, knock me over with a feather but if that were true, good chance you would not be here asking.
If modification to the existing system is what you are after, perhaps you should have made that clear in the beginning.
Only advice that can be forwarded in that case would be to ask around on the sites that specialise in this type of thing.
RC Groups might be a good start.
https://www.rcgroups.com/forums/index.php
Edit:....... appears you already have with no replies....I'd say offhand it's not possible or too hard basket or not worth the bother.
https://www.rcgroups.com/forums/showthread.php?4361831-Mini-Quad-As-a-Webcamera
Delta Prime
Jul 29, 2020
2,996
My description is how to use it as a USB web camera for every other quadcopter except yours.
Given the lack of information you provided initially. And yes it can be done and has been done as you described it with an app and an SD card. "Hoping to keep you in suspense". Toodaloo.
Creative_Maker
Jun 30, 2023
8
suspense ..can you please pen it with dotted pointed what more info will be required...)))) Thanks
Creative_Maker
Jun 30, 2023
8
to be frank i already posted there will no response either... :) thanks
Creative_Maker
Jun 30, 2023
8
is it possible with HDMI cable with HDMI to micro usb adapter attached to the mini quadcopter.???
