I have built a simple PWM drive with a 555 and an op amp. The op amp drives a trans which drives a mosfet. However the mosfet seems to be latching.
The mosfet is conducting, with no gate signal present, a test bulb lights brightly. When I apply the PWM to the gate the bulb dims as it should. I'm using an IRF 530.
I simplified the circuit just driving straight from a 555, again it works fine until the gate signal is removed when it lights the bulb brightly again. PS is a 12V batt.
I put a 91 ohm resistor in the gate line and a 100 microF cap across the power supply, but it made no difference.
Can someone help me fix the problem?
