JosephKK
- Jan 1, 1970
- 0
Well, no, the point is that high end turntables like the Rek-O-Kut did
not use gear drive or toothed belt drive because of the tooth passing
noise these produce; they used flat belt drive and the seldom needed
adjustment was to compensate for wear - or allow slight pitch
adjustment for those with perfect pitch. (I might have one of
those stored in my barn somewhere too, but I think I threw it out.)
BTW synchronous motors not run from variable frequency drives have a
second rotor winding for starting purposes (amortisseur winding), so
the motor starts as an induction motor with slip then locks in as
synchronous.
Some of them do. There is a variation called a salient pole motor,
some are spun up by induction motors before applying power; and some
are just "hard started". Almost all synchronous motors are 3 phase.
