Multiple PCB Combination into a single PCB
pblanos
Nov 27, 2013
13
I have a circuit arrangement project with different parts for a prototype portable device which you can find here. I would like to make a single pcb out of this circuit so that I can fit it the portable device. As it is, it works perfectly. I also have all the eagle files for the different parts. Can anyone guide me how to combine all these parts into a single pcb having the same functions. Should I try fritzing, eagle? I am actually a new and inexperienced engineer.
Thank you in advance
jpanhalt
Nov 12, 2013
426
When you say you have the Eagle files, do you mean at the component level, even for the Bluetooth shield?
On the other hand, if you want to assemble the sub-assemblies onto a single carrier board, then the place to start is to make "devices" for each of the sub-assemblies.
The first option could be quite tricky because of the RF design. The second would be quite easy.
Do you know how to make devices with Eagle? Which version of Eagle do you have? It is possible that if you are using the free version your allowed board size may not be adequate.
John
