legg
- Jan 1, 1970
- 0
I note in the specs for the M26 or X26 taser that the pulse rate is
~15 pulses per second, dished out in continuous10 second increments.
http://web.archive.org/web/20050204222428/www.taser.com/documents/carletonuniv_000.pdf
Recommended use is three closely-spaced trigger pulls, which is the
limit of possible accumulated instructions, producing a continuous 30
second interval of pulse application.
http://www.taser.com/products/consumers/Pages/TASERX26C.aspx
30 seconds seems like quite a long time, to me. It probably seems
longer if the electrodes are actually stuck in your but.
When you hear two tasers deployed, with scarcely 3 chimpanzees
time-space between them, and both 'applicators' are wiggling their
trigger fingers, it sort of makes you wonder what kind of patterns of
pulsed current there are, being generated in the body of the victim.
This is particularly speculative as the taser's inter-electrode
distances increase from the nominal 2.5cm to as much as a couple of
feet, on deployment at a 12 foot distance.
I've never read a lab report, seen a model result, or watched a
freindly law enforcement demonstration on willing volunteers that used
interelectrode distances other than the 2.5cm book value, repetition
rates or periods as described in the applications manual, or multiple
simultaneous taser sources.
Seeing as targets seem to insist on croaking, when such circumstances
'occur', perhaps the real-life situation might be investigated more
realistically in the lab, and the results reported more generally in
the literature?
Just a thought.
RL
the literature?
Just a thought.
RL
