Need 200w open frame power supply
Y
Yzordderrex
Greetings,
I am modifying a piece of gear to put out more power and need to get
hold of a 24vdc open frame power supply. The present design has a
100w power supply, but I am hoping newer designs can double the power
in a similar footprint. I never bought an off the shelf design
before, alway did them myself. So I have no idea what manufacturers
would be good to look at. I see a company called astrodyne in MA.
Any other companies I should look at?
The present power supply is the VLT100 in the link below.
http://www.celetronix.com/eos/eos_prod_eos.htm
regards,
Joerg
Yzordderrex said:
Greetings,
PowerOne and Condor come to mind. Nothing is perfect in the world of
switchers but I had mostly positive experiences with them.
Rich Grise
Greetings,
I am modifying a piece of gear to put out more power and need to get hold
of a 24vdc open frame power supply. The present design has a 100w power
supply, but I am hoping newer designs can double the power in a similar
footprint. I never bought an off the shelf design before, alway did them
myself. So I have no idea what manufacturers would be good to look at. I
see a company called astrodyne in MA. Any other companies I should look
at?
I've always had excellent luck with Lambda:
http://www.lambdapower.com/
Good Luck!
Rich
F
Frithiof Andreas Jensen
NOT wicor - unless the kit is in a location that you like to travel to often!
TOKO does some cheap & nasty open frame supplies - if they have to be cheap and
noise is not so important.
Brian
Yzordderrex said:
Greetings,
regards,
I have had good results with following:
Tamura of America (was Taiyo Yuden)
Power One
In my experience, following seem to produce units
having reliability problems and/or tend to not meet
their published specs:
Vicor
Astec
Phihong
Mean Well
Michael A. Terrell
Power One
Those are the brands that Microdyne was using when I left.
Vicor
Astec
Phihong
Mean Well
We had problems with all of them. Some never made it through the
first test in engineering.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
