need help for cfl lighting
pier1
Aug 21, 2006
180
i need help to make a circuit which consumes very less current for lighting up a cfl tube (9watts) with starter from a 6 volt battery . please help me .
audioguru2
Apr 6, 2004
12,022
9W for the light tube and maybe as much as 1.8W for the voltage stepup circuit is a total power of 10.8W.
Therefore the current from a 6V battery is 10.8W/6V= 1.8A. Do you have a huge battery to supply a current so high?
pier1
Aug 21, 2006
180
i saw a circuit that has few components and has a 9 watts cfl tube, but the whole circuit pulls only 700mA from a 6volt 4Ah battery . That is why i asked for it . please do help me .
audioguru2
Apr 6, 2004
12,022
700mA from a 6V battery is only 4.2W. The inverter is about 80% efficient so the 9W bulb gets only 3.36W. That would be quite dim. Is that what you want?
pier1
Aug 21, 2006
180
that is not a bulb . it is a compact flurocent lamp(tube) with a built in starter . while it starts the lamp flickers about 2 to 3 seconds then goes to steady state
audioguru2
Apr 6, 2004
12,022
A compact fluorescent light needs a ballast to make it work. A very old ballast was a big coil of wire as an inductor, then it had a starter with mechanical contacts or a small neon bulb.
Modern ballasts are an electronic circuit with a power oscillator driving a high frequency small stepup transformer and a high voltage current limiter.
Our projects section has two projects that light small fluorescent tubes. The 1st project uses a 6V or 8V battery and its bulb is about 9W but doesn't say. It uses a transformer but the project doesn't show it or say any spec's about it.
The 2nd project is similar but needs a 12V battery.
http://www.electronics-lab.com/projects/motor_light/002/index.html
http://www.electronics-lab.com/projects/motor_light/027/index.html
pier1
Aug 21, 2006
180
no that dosnt work out . i really need it from a 6 volt battery that draws less current . please try to help me cause i am badly in need of it .
audioguru2
Apr 6, 2004
12,022
The only way to reduce the battery current is to reduce the circuit's power output. That makes the light tube less bright.
pier1
Aug 21, 2006
180
but will that effect the brightness of the tube ?
audioguru2
Apr 6, 2004
12,022
Of course. It takes power to make light. Less current from the battery is less power so is less the amount of light.
pier1
Aug 21, 2006
180
but the circuit i saw was bright enough and draws only 700 mA from the 6 volt battery . I think BPL has started one without starter in the tube . how does that work then ?
Ive attached an image of the tube . u can have a look at it .
audioguru2
Apr 6, 2004
12,022
I have lots of newer compact fluorescent bulbs in my home. The tube is a spiral. Most use 15W and a few use 23W.
The electronic ballast which is part of my bulbs pre-heats the filaments at the ends of the tube for a moment then gives it a high voltage spike to start it without flickering.
The ballast has a rectifier and filter for the mains then a 40kHz stepup inverter. A current-limiting capacitor feeds the tube.
"700mA from a 6V battery is only 4.2W. The inverter is about 80% efficient so the 9W bulb gets only 3.36W. That would be quite dim."
audioguru2
Apr 6, 2004
12,022
It is a huge paper with a tiny schematic on it.
Make it, measure its current and see how dim or bright it is.
Are you going to take it camping? The bears might eat it. ;D
pier1
Aug 21, 2006
180
i already measured its current . as i said earlier it draws only 700 mA from a 6 volt battery . and the brightness is very good and sufficient . but i dont know the transformer details . thats the problem . i know all the other values .
audioguru2
Apr 6, 2004
12,022
I have never seen a transformer with an extra winding like that. It must be custom-made for the light.
pier1
Aug 21, 2006
180
since it self oscillating it must be the one for oscillating , some say that it is a feedback winding .
audioguru2
Apr 6, 2004
12,022
It is a feedback winding. Your schematic shows it shorted, and a resistor is missing for one of the transistors.
