NEED HELP FOR SONY KV29FX30B
makuka
Jun 4, 2004
6
I HAVE NO RED COLOUR FROM ICOO1. CAN YOU HELP ME? MAKY
electrodoc2
Feb 11, 2004
57
[glow=red,2,300]***__-- TUBE BASE VOLTAGES CAN AND WILL!! BITE--__***[/glow]
I'm not familiar with this model but providing the chip that you refer to isn't fastened to a heatsink then this procedure is a failsafe way of finding where the fault is. It can be used on any transistor driven gun array and i always employ this method.
First check the drive circuit on the tube base, there will be a plug going from the tube base to the main board where the IC001 lives. three of these leads should be traceable to the red,green and blue drive transistor base connections. disconnect / cut the wires for the red and blue and swap them over. Then if your screen still lacks red there is a fault on the tube panel or possibly the tube itself, if your screen lacks blue then the fault lies within the RGB driver chip on the main board.
Reconnect your swapped leads and then check the tube by following the track from the 'BLUE' drive transistor to the relevant pin on the tube base socket and desolder the pin, do this with the 'RED' pin also. Then with a thin piece of insulated wire soldered to the 'BLUE' tube base boards socket pad* (see picture) touch the other end of the wire to the tube sockets 'RED' pin.
