Need help identifying and replacing component
Minder
Apr 24, 2015
3,561
Q usually indicates a transistor.
Does it have any identifying marks or how many leads?, If not the only hope is to try and reverse-engineer it and attempt to come up with a sub.
There is only Four terminals!
phlox
May 19, 2012
77
the only markings i can now see are a " J " and it has 3 legs on one side and a tag at the top.
i found the schematic if that would help
in the second pic bottom left corner above the hole is Q1
[Mod edit ... 3 legs]
phlox
May 19, 2012
77
i actually just found a pic on google showing the component where by i could read the markings.
Its an S8050 NPN Transistor
Now i just need to find a replacement.. Thank you for your help. :)
Alec_t
Jul 7, 2015
3,821
Almost any general-purpose NPN switching transistor can replace Q1.
Minder
Apr 24, 2015
3,561
With those existing resistors, you could even drop a 2n7000/2n7002 in there that should work.
M.
phlox
May 19, 2012
77
hey thanx all, i found an replacment ( PMSS3904) from an old LCD Monitor PSU and the specs are basically the same except the replacement can go a bit higher in voltages but i replaced it and all is good.
Thanks for all the help.
