Need Help Identifying Collector, Emitter, and Base
14,487
I found the data sheet but I can't identify which pins belong to the emitter, base, and collector.
it doesn't have E, B and C because it is a FET
It has a G, D and S gate drain and source and your datasheet shows which is which
GeneralBones
Jan 24, 2017
19
Ohhh okay so I can't use this for a Tesla coil? I'm assuming it won't work like a transistor with e b & c
GeneralBones
Jan 24, 2017
19
Something like this except with a bigger coil and PSU, something like 12v-24v idk I'll experiment. I already mad thst circuit and it works pretty well
duke37
Jan 9, 2011
5,364
A fet will work as a replacement for a bjt. You will need less control current but much more voltage. You still have not shown a schematic (US).
