oldmanbiker
- Aug 1, 2006
- 10
- Joined
- Aug 1, 2006
- Messages
- 10
I need to blink an array of 78 white leds. I figure that I need to switch about 4.0 volts at 1.6 amps.
I want to take a $1.00 blinky led as a signal source and drive a TIP120 with it. When using a TIP120 as a switch, can I just wire it in series with the LED array ground connection? Also, I figure that the darlington in the TIP120 is high gain, so I should be able to saturate it with the blinky led. Will connecting the blinky led from V+ to the base do it?
