Gene E. Bloch
- Jan 1, 1970
- 0
In comp.sys.ibm.pc.hardware.misc William Sommerwerck
Very much so, but mostly in the same sense that a glowing
pice of metal is a quantum device....
Arno
No, not at all in the same *sense*, but to the same *degree*. The
fluorescents use electron transitions in Hg to generate a line
spectrum, and then a fluorescent coating inside the bulb to convert the
lines in question into new lines and bands. This is in no way
comparable to black-body radiation, which is a continuum. This, of
course, is an *opinion*
However, both are still quantum-mechanical devices at bottom. In fact,
it has been said that it was trying to solve the BB radiation problem
that led Planck to the discovery of his constant: he took the limit of
something as some differential went to zero and it didn't work. But he
got the right answer when he set the differential to a finite value,
around 6.27E-27, IIRC.
Close (sort of): Google gives me "Planck's constant = 6.626068 × 10-34
m2 kg / s", so I left out the second 6 - but I am used to it in cgs,
rather than mks, so the exponent is correct. That *would* be more
believable if I had expressed the units, erg-sec, above
