john monks
- Mar 9, 2012
- 685
- Joined
- Mar 9, 2012
- Messages
- 685
They actually do. Firstly in a vacuum capacitor only some electrons accumulate on the negative plate. The rest are some distance from the plate although we maybe only talking about nanometers or less. And as a percentage of the total number of electrons on a plate of a capacitor we are talking about a very small number. We must keep in mind that an electron is going to migrate when a force is applied to it. And in this case the greatest force occurs between the plates when the capacitor is charged.
Taking the spacecraft analogy. If a negative one million volts is applied to a spacecraft in orbit the hull becomes charged. But where does the greatest charge take place? It certainly would be on the outside because there is a very little voltage gradient taking place inside the spacecraft so the astronauts feel nothing. Therefore the only place you will get a piling up of electrons is on or actually near the outside of the spacecraft.
Now certainly even with one million volts as a percentage of charge particles the actual number of extra electrons on the outside of the spacecraft won't be much different than on the inside. It's just that the outside will have an excess amount.
Sorry donkey, our messages crossed. It is hard to eliminate the two vertical capacitors. They are there if they are one millimeter away to 10 kilometers.
I guess I don't understand where your confusion is but a capacitor does not need a charge to have a voltage across the plates. An electrostatic force coming from somewhere else can induce a voltage. In your case where you have several plates between any two plates can be considered a capacitor.
