Old Radar Display, need info
  • Thread starter Jacques St-Pierre
  • Start date
Jacques St-Pierre
I need to power up an old Military Radar display unit build by Kelvin
Hughes, code no RDS-A1, do any one know what was the supply voltage,
frequency and power connector pinout?
I suspect it may be 120Vac at 400Hz, but I am not sure. I also assume power
input was going to the power switch, but I am not sure too. So any hint will
be helpful at this point.
Bye
Jacques
PeterD
Bye
Jacques
Aircraft display, or ground display? There should be a tag (plate)
indicating power requirements near the power input connector.
Jacques St-Pierre
Sadly, I can not find any tag (plate). What I suppose to be the power input
is not even named, just a multipin military style connector. I figure it
must be power input since the unit have no other connector (except video &
sync). Two wires are route to the power switch, so they must be it, but no
luck to power it from there, maybe the unit is also defective.
Jacques
PeterD
Jacques
Consider posting images on a web site. Sides, back, front, covers
removed.
