Hi Kevin,
What is a phase compensation capacitor at an opamp's inputs?
I have seen a capacitor added between inputs to stop the input transistors from rectifying a strong nearby radio signal.
Most opamps have a built-in phase compensation capacitor.
Because an opamp has a very high open-loop voltage gain of about 200,000 and a lot of transistors, its phase-shift exceeds 180 degrees at very high frequencies that would cause it to oscillate when negative feedback is applied. So the internal phase compensation capacitor is added to reduce the open-loop gain to below 1 at the frequency when the circuit's phase-shift becomes excessive. Then it can't oscillate.
An old 741 opamp has its internal phase compensation capacitor selected to reduce its open-loop gain to 1 at 1MHz. It is just a single RC network (90 degrees max phase shift) so the max gain at 100kHz is 10, the max gain at 1kHz is 1000 and the max gain at 10Hz is 100,000. Negative feedback can be applied with two resistors to make any smaller amount of gain you want, below these frequency/gain limits.
The input resistance of an opamp is very high. So very little current is needed in the negative feedback resistors' voltage divider. The output transistors are complimentary emitter-followers that can drive about 20mA max into a load.
