optical punch card reader
mattsains
Jun 8, 2012
35
Hello
I'm thinking of making a punch card reader as an arduino project. I'll have an LED for each punched row, and some sort of light sensor on the other side.
Would an LDR be reactive enough to pick up a chads (holes) if I'm going to be swiping this card through the reader?
Is there something better I should be using? I've only worked with LDRs before; I'm not sure what is what when it comes to photo semiconductors, so some buying advice would be nice if LDRs aren't sufficient
PS: A Youtube video of what I'm wanting to achieve, except using metal brushes instead of optics:
GreenGiant
Feb 9, 2012
842
I personally would use phototransistors, this will give you a clean either on or off if it senses anything, rather than a small shift in the readings.
There are some questions though...
What are the cards made out of?
What will the placement and number of possible holes be?
What is the output going to be?
Does it need to swipe or can you insert, wait and then remove?
Green
14,317
As far as I remember the holes in a punchcard are spaced rather close compared to the size of a typical LDR (there may be very small ones out there, but the ones I know are rather big). So you would have to stagger the LDRs and use the µC to correct the displacement of the signals caused by the staggered LDRs.
Anothe rsolution would use photodiodes. These come in very small packages (even SMD) and it should be possible to space them as close as required for the punch card raster.
See here: http://sales.hamamatsu.com/assets/applications/SSD/si_pd_circuit_examples.pdf for photodiode applications.
Harald
mattsains
Jun 8, 2012
35
Thanks for the replies!
I'm thinking of rolling my own punch cards as in the video, so space isn't an issue (read: I can't solder SMD :p )
Cards will be made out of something opaque enough, probably card of considerable thickness. This is more a data reading experiment than a perfect replica of legacy. I'm thinking of, say, five rows which I'll service with five LEDs and sensors. (might need to be hooded to stop light leaking into other sensors)
I do want to swipe... I'll probably have a clock row (again, as in the video) so I know when the bits are passing through.
Could you explain a bit about how phototransistors work? What exactly do they do in the presence of light?
Harold, thanks for the link to the photodiodes, I'll study it a bit.
mattsains
Jun 8, 2012
35
I suppose, in essence, I'm asking whether an LDR will pick up the rapid pulsing of light from swiping this punch card (from the perspective of a sensor) or is it going to be too sluggish to respond to this change
GreenGiant
Feb 9, 2012
842
Phototransistors act like switches, when light is present it will either open or close (depending on the type) like a switch, see here
you should be able to line up the LED's (probably better off using an IR LED and transistor) so that when you slide the card the Arduino can read multiple lines though that would be pretty complicated, unless you go from parallel to a serial stream of numbers (1's and 0's) which the Arduino could read
mattsains
Jun 8, 2012
35
cools! Thanks for the link to the photo trannies.
I think you're probably right about doing serial. I'll go with that. Thanks for the advice!
GreenGiant
Feb 9, 2012
842
Like I was saying, LDR's is just going to give you a small change in readings, where a photdiode, or a phototransistor will give you a more clean on and off
so basically a sine waveform vs a square
GreenGiant
Feb 9, 2012
842
gorgon
Jun 6, 2011
603
It will be both too sluggish and too big to implement easy. For a swipe reader the electronics and optics must be significant faster than the fastest person using it. If you just want to experiment, it's ok to be inside the user envelope, but only a while.
You should use an optotransistor, one for each bit/position.
You should also be aware of ambient electric light, where you'll get 50/60Hz optical noise/overload.
You may reduce this with a filter and IR-LEDs as light sources.
TOK ;)
mattsains
Jun 8, 2012
35
they seem to leave off the base. do you recommend getting one with a base?
The base is connected to the light coming in!
mattsains
Jun 8, 2012
35
Figured! ;) but I have read that some have a base leg so that you can bias the light coming in (in my murky knowledge of electronics that means you can make the transistor more or less sensitive)
For this purpose you won't need one with a base connection.
There are other ways to control sensitivity in any case.
eptheta
Dec 20, 2009
188
hahaha ! "photo trannies"
This should be a fun project for you. T̶h̶e̶ ̶o̶n̶l̶y̶ ̶t̶r̶o̶u̶b̶l̶e̶ ̶I̶ ̶t̶h̶i̶n̶k̶ ̶y̶o̶u̶'̶l̶l̶ ̶h̶a̶v̶e̶ ̶i̶s̶ ̶d̶e̶f̶i̶n̶i̶n̶g̶ ̶t̶h̶e̶ ̶d̶e̶l̶a̶y̶ ̶f̶o̶r̶ ̶t̶h̶e̶ ̶'̶0̶'̶ ̶s̶t̶a̶t̶e̶ ̶w̶h̶i̶l̶e̶ ̶s̶w̶i̶p̶i̶n̶g̶.̶ ̶Y̶o̶u̶ ̶s̶h̶o̶u̶l̶d̶ ̶t̶r̶y̶ ̶a̶n̶d̶ ̶m̶a̶k̶e̶ ̶y̶o̶u̶r̶ ̶p̶r̶o̶j̶e̶c̶t̶ ̶s̶w̶i̶p̶e̶-̶s̶p̶e̶e̶d̶ ̶i̶n̶d̶e̶p̶e̶n̶d̶e̶n̶t̶.̶ ̶
I̶ ̶n̶o̶t̶i̶c̶e̶d̶ ̶i̶n̶ ̶t̶h̶e̶ ̶v̶i̶d̶e̶o̶ ̶t̶h̶a̶t̶ ̶t̶h̶e̶r̶e̶ ̶a̶r̶e̶ ̶t̶w̶o̶ ̶l̶i̶n̶e̶s̶ ̶o̶f̶ ̶h̶o̶l̶e̶s̶ ̶i̶n̶ ̶t̶h̶e̶ ̶p̶u̶n̶c̶h̶ ̶c̶a̶r̶d̶.̶ ̶T̶h̶a̶t̶ ̶w̶o̶u̶l̶d̶ ̶e̶l̶i̶m̶i̶n̶a̶t̶e̶ ̶d̶e̶p̶e̶n̶d̶e̶n̶c̶e̶ ̶o̶n̶ ̶s̶w̶i̶p̶e̶-̶s̶p̶e̶e̶d̶.̶ ̶I̶s̶ ̶y̶o̶u̶r̶ ̶c̶a̶r̶d̶ ̶d̶e̶s̶i̶g̶n̶ ̶g̶o̶i̶n̶g̶ ̶
t̶o̶ ̶b̶e̶ ̶s̶i̶m̶i̶l̶a̶r̶,̶ ̶o̶r̶ ̶a̶r̶e̶ ̶y̶o̶u̶ ̶g̶o̶i̶n̶g̶ ̶t̶o̶ ̶t̶r̶y̶ ̶a̶n̶d̶ ̶g̶e̶t̶ ̶i̶t̶ ̶d̶o̶n̶e̶ ̶w̶i̶t̶h̶ ̶j̶u̶s̶t̶ ̶o̶n̶e̶ ̶r̶o̶w̶ ̶o̶f̶ ̶h̶o̶l̶e̶s̶ ̶?̶
EDIT: Sorry, I just read your post about the clock row.
I guess this is now just a 'good luck' post.
mattsains
Jun 8, 2012
35
will definitely have a "clock row" which will be all punched. Then I will read the state of the other rows when I get a signal from the clock row
mattsains
Jun 8, 2012
35
It might be a bad idea, but I want to get this to work in the visible spectrum. I hate buying invisible lights, and I'd also like to use these components for other things later
