Oscilloscope Bandwidth!
Terry Given
John said:
I've finally become a full convert to digital, color, LCD scopes. My
personal scope (in my office) is a Tek TDS2012, which handles 90% of
what I do. The digital storage, averaging, and FFT things are neat, as
it the fact that you can hold it in one hand.
John
I carried my pair of 7904's from MIT to Worcester square, in the south
end, with a backpack full of books. I regretted it the following day.
Incidentally, I bumped into Win there that day, also looking at books,
although I'm sure he doesnt remember (although I waffled about the 3MJ
flywheel I was working with) :)
Cheers
Terry
Myauk
One question, again!
I measured the composite video signal by setting the display to PM5644
test card.
The problem is that although setting to time/div = 5,10,20 micro
second, volt/div = 200, 500 milli volts, and trigger values around 40,
344,420 and -100 milli volts, I just could not get the stable captured
waveform. (colour burst was clearly seen in each wave from, but there
are several different patterns displayed every time I pressed the
RUN/STOP button.). Isn't it normal? I am using TDS 744A 500 MHzz
Tektronix oscilloscpe.
More over I would like to have the best possible settings for measuring
Y Pb Pr and S Video Y, C signals.
Can anybody share me the links for example measurement of those video
signals?
Or some example waveforms.
I have some measured waveform but still I would like to have more just
for knowledge.
Peter Bennett
test card.
It is normal to see a "mess" during the "active picture" portion of
the scan line, as you are looking at all scan lines at once. If,
instead of the PM5644 test signal, you look at a colour bar or gray
scale test signal, the active portion of the video signal will make
more sense.
To see these signals independently, you would have to look somewhere
within the equipment where they exist as independent signals. It
sounds like you are looking at a composite video signal at present - a
normal oscilloscope can't isolate the individual colour components in
that signal.
signals?
for knowledge.
Peter Bennett, VE7CEI
peterbb4 (at) interchange.ubc.ca
new newsgroup users info : http://vancouver-webpages.com/nnq
GPS and NMEA info: http://vancouver-webpages.com/peter
Vancouver Power Squadron: http://vancouver.powersquadron.ca
Myauk
that signal.
Actually I am measuring different outputs, not isolating them from
CVBS.
The outputs I am going to measure are YPbPr, S Video, and Composite
Video Outputs from a DVD Player.
Is there any test discs available in the market for colour bar output?
joseph2k
CVBS.
In your position i would just record one. But i may be wealthier than you.
Myauk
Thank you very much for all your answers and encouragements.
Now I am working well with my measurements.
I have almost finished reading XYZ of oscilloscope to understand more
about digital oscilloscopes.
And I found the required PAL and NTSC Test Discs for my wave form
measurement.
I also found the complete list of test patterns for NTSC and PAL at
www.convergent-design.com.
Without the discussion this group, I would not be able to do this that
fast for my first measurements.
I am now quite motivated to buy an oscilloscope very soon.
Best Regards
