Overkill LEDs and PWMing with electric switch
Braeden Hamson
Feb 18, 2016
240
Hey guys,
So I'm building a backlit switch box, in the style of aircraft panels. I bought some LEDs modules without looking at the datasheet...
http://optekinc.com/datasheets/OVM12F3R7.pdf
As you can see they're beefy. I want to PWM these LEDs. I was thinking I'd use a 555 timer chip and configure it to work as a PWM module. I'd then use some kind of electric switch I was thinking a relay or some kind of transistor, to actually switch the LEDs on and off because I know a 555 can't take that kind of voltage. If anyone has a good guide on the different types of transistors (MOSFETS JFETS Bobba Fetts) That'd be greatly appreciated.
Alec_t
Jul 7, 2015
3,821
A mechanical relay will be too slow. MOSFETS would be the most practical switching devices.
Different LED colours have different current maxima. Which colour are your LEDs?
How many modules do you plan to combine?
What power supplies do you have?
These are a logic level switched mosfet which will handle quite a bit of current, they are cheap @ $4.00 odd for 10, plus you can use them in micro circuits as well later on maybe.
FQP30N06L
Look on Ebay.
cjdelphi
Oct 26, 2011
1,166
Hey guys,
Oh i'd love to see a mechanical relay try that, you'd need a SSR / Triac for switching mains...
If not mains use a transistor that can carry the current required
cjdelphi
Oct 26, 2011
1,166
0.5w/12v not much power
Any power transistor (npn) and a 500ohm resistor from the 555's pin3 to the base of the transistor. .
hevans1944
Hop - AC8NS
Jun 21, 2012
4,986
FQP30N06L
Look on Ebay.
Holy cow, @Bluejets! That's one nice little MOSFET! Time to buy a ten-pack of these with free Prime shipping from Amazon to supplement my stock of 2N7000 puppies. You adventurous types can look on eBay for better prices. Here is a link to the Fairchild Semiconductor datasheet. Impressively low on resistance. Thank you Bluejets!
cjdelphi
Oct 26, 2011
1,166
Why not use a regular transistor over a fet? They're cheaper
