PC PSU driving relay
  • Thread starter Dirk Bruere at NeoPax
  • Start date
I am using the +12VDC from a PC PSU to switch mains using a relay ie
when the PC turns on mains power gets supplied to some amplifiers.
Do I need diode protection across the relay coil for when the PC PSU
switches off, or do such PSUs have such protection built in?
Phil Allison
"John Larkin"
If the relay coil is connected directly to the 12 volt supply, you
don't need any other parts. There will be no flyback voltage.
** So this Dirk dude imagines he is an engineer ??
ROTFL !!
..... Phil
Jasen Betts
The PC powersupply has a bridge rectifier and some large capacitors on
the 12V output, if the capacitors don't suffice to provide a slow
enough voltage drop the rectifier will clamp the flyback peak voltage
to somthing smaller than -1V
"John Larkin"
ROTFL !!
Strangely enough, this is the first time I have ever used a mechanical
relay.
Phil Allison
"Dirk Bruere at NeoPax"
relay.
** That supposed to be some kind of excuse ?
It ain't.
It ain't.
Based on your past record I assume your excuse is mental illness
Phil Allison
Dirk Bruere at NeoPax = ****
** Scum like you need a bullet in the head.
Jamie
Didn't they take the guns away from you guys? I can see
why.
I understand you people only want to be good samaritans
and clean up society but come on now, it appears to me, it
may create empty streets with attitudes like yours. I mean,
the worthless politicians won't have any brain dead voters
to keep them in office so they can live free off our backs.
Jamie
