PCB Reference Designators
TT
Hi All,
Can anyone point me to a webpage or standard that lists the international
standard for PCB reference designators? eg, R1 for resistor, C5 for
capacitor etc.
In particular, what is the standard for PCB headers and receptacles? Is it J
or P? Also after what should be used for a PCB link.
Mark Harriss
TT said:
Hi All,
capacitor etc.
Here's some pin name abbreviations from Altium:
http://www.altium.com/files/libraries/LS0001_PinAbbreviation.pdf
Calling a connector J1 J2 etc., is a hangover from the American
name "Jack" and is just their name for a socket. P1, P2 etc just
means a plug, so P1 plugs into J1.
I'm not sure what you mean when you mention a link, as in
a short piece of wire on a PCB usually to pass a connection over
the top of some PCB tracks without touching them, it's a cheapy
way to avoid having to use a double sided PCB if you can just
have a few links instead. I don't think there's any naming standard
for a link at all.
David L. Jones
TT said:
Hi All,
capacitor etc.
There effectively is no "standard", at least none that any sort of
majority actually follow. Most do it on an internal company standard
basis, as each companies requirements are different. Standards can also
change between products with different complexity too. Where no
standard exists within your company, the designer usually does whatever
they like.
If you *really* want something to follow, then I believe there is an
IPC standard available, and also is (or was) an Australian standard
available too, but I believe the Australian PCB standards were dropped
in favour of the IPC standards. The numbers escape me though, try:
http://www.ipc.org/ContentPage.aspx?pageid=4.1
A quick search bought up IPC-DRM-18F which may help
From memory though the IPC designator names are pretty stupid, and no
one I know actually uses them.
Dave :)
swanny
TT said:
Hi All,
capacitor etc.
I've seen larger Australian organisations adopt the Australian Standard (SAA HB3-1986). However the designators in this
standard differ from what you usually see in schematics elsewhere (V for semiconductor, X for connector). Most of the
designators we see in schematics tend to come from either US or UK standards.
David L. Jones
TT said:
Hi All,
capacitor etc.
The IEEE have a standard: 315-1975
Dave :)
David L. Jones
Mark said:
That's a superseded one isn't it?
Maybe, I don't know. If it was, then what superseeded it?
It was reaffirmed in 1993
There is also 315A-1986, no idea what the difference is or which one
(if any) is the most recent. In any case it's really only an
Amercian/US standard I believe.
Dave :)
Mark Harriss
Dave :)
Well the Altium website does say something along those lines
about 315-1975 (reaff. 1993) and 315A-1986 but on the IEEE
website there was some blurb about 315-1975 no longer being a
valid standard and being listed for historical purposes along
with a some other standards.
Mark Harriss 写é“:
We are manufacture low cost, high quality PCB prototypes in China.
we also supply RoHS Compliance,Leed Freed PCB prototype.
Silk masks are produced for the same price
Send us a PCB file and we will reply promptly with a quote.
We can assemble components for your company.
if any question, Please email us with your questions.
We sell high quality HDI PCB's.
accept delivery times are prompt.(quick turn)
We can supply color PCBs board(Example: Blue,
Black,Red,Green,White,yellow.)
Mail: [email protected] or [email protected]
E-mail pcb files to us and we will provide a prompt quote.
We sebd PCB via DHL or UPS ( Approx 1 day from Chins to the USA)
Product Name: Printed Circuit BoardPlace of Origin: ChinaFeatures:
1) Surface finish: hot air solder leveling, entice, immersion gold,
carbon ink, gold finger, peelable mask
2) PCB file format: protel,powerpcb,Gerber file,Engle....
3) Profile: routing, punching, V-Cut, chamfered
4) Number of layers for mass production: 2 - 12
5) Finished copper weight from .25 to 3oz
6) Minimum finished hole size .006"
7) Min. trace .004" - Min. space .004"
8) Max. panel size: 18" x 24"
9) Printed circuit board final thickness from .016" to .125"
10)soldermask /Legend in a variety of colors
(Green,White,Black,Yellow,Red..)
Lead times: 2 layers( 1 days, 3 days, 5 days) Ships next day.
4 layers( 2 days, 5 days, 7 days)
6 layers( 3 days, 5 days, 8 days)
Min Qty 3pcs.
Web:www.nj pcb.c o m
mail: sales@nj pcb.c o m
Contact Person: Mr. Ding JiaBao
Website: http://www.njpcb.com
E-mail: [email protected] or [email protected]
Any advice will be greatly appreciated!
if any question,Please send e-mail to us,we will reply as soon
