Peavey XRD680TB problems after a storm
This unit came in after a big electrical storm. When power is applied you hear a slight hum from the speaker outputs but it does not respond to any input. It seems to be a problem in the output or driver section but this is difficult to trace. Does anyone have a service manual for this? Thanks, Lenny
N
N_Cook
Probability-wise in those circumstances, whatever can least accommodate
voltage surges, so anything requiring a nice low 3.3 or 5V supply ie the
main system control micro knocked out first
chuck
Peavey will usually email schematics for free. Chuck
This unit came in after a big electrical storm. When power is applied youhear a slight hum from the speaker outputs but it does not respond to any input. It seems to be a problem in the output or driver section but this isdifficult to trace. Does anyone have a service manual for this? Thanks, Lenny
I found that Peavey employs several FETs on the inputs to some of the amplifiers in the unit. These are apparently "sacrificial" components which short during an overload thereby protecting the associated IC's. I found three shorted ones. I ordered replacements from Peavey and will see what happens.The clue was that the "X" voltage which is supposed to be -22v was zero. The shorted FET's essentially shunt it to ground. Lenny
