Here's another test:
(1) Divorce the GSM from the Timer board.
(2) Power up the Timer board.
(3) Monitor the Opto + - input with your DMM
(4) Momentarily short the Opto + - Input.
(5) Make note of voltage reading immediately after opening the short.
I would expect ~+12V when open and ~0V when shorted.
If all else fails post a clear photo.
Chris
You forgot #(5). It's important! Also, is it timing out as it should?Exactly as you predicted
12v before i short them
And 0 when i short them,also motor starts turning when i short them and both LED-s are lit.
Ivan
It rises to 12v as soon as i open the short
It shows 8-9v and than 12v on DMM.
Yes, timer is set to turn off motor after 2-3 seconds
I never used vibrator motor,i disconnected it straight away,only used the wires,and i dont have that tiny motor anymore,can i use resistor instead ?
measured base-emiter voltage,0.64 constant when it is not ringing and 0-0-7 pulses when it is ringing
Ivan
Yes, a resistor would be better. Better yet,.. do you have a Red LED? If so connect the LED in series with the 1KΩ base resistor. The ~1.9V drop of the LED will probably solve the problem. Anode to GSM ringer (+) and Cathode to the 1K.When it Is only powered on but not ringing
When i connect (-) from DMM to it's battery and measure voltage on both + and - output i get 0v.
When it is ringing i get 0v on (-) and 3.30v to 0 intervals on (+)
