power circuit
oldman2021
Oct 31, 2021
Good evening
First, accept my great gratitude and appreciation for this valuable site
Secondly, I would like to ask you about the possibility of supplying me
with an electrical circuit with a power of 100 amps and a variable current from 1 to 220 volts.working
M Salman Sarwar Khan
Jan 26, 2022
15
The unit of power is not amps. you should use Watt. as far as I understand you question, you want a 100 watt supply with volts vary from 1 to 220 volts. The output power we can calculate by using formula P=VI so you can vary current and volt to get desire output power. To vary current and Voltage you can use transformer.
leverperfect
Jan 13, 2023
4
The unit of power is not amps. you should use Watt. as far as I understand you question, you want a 100 watt supply with volts vary from 1 to 220 volts. The output power we can calculate by using formula P=VI so you can vary current and volt to get desire output power. To vary current and Voltage you can use transformer. cuphead
Are there any reputable transformer brands you can recommend to me?
