Power Supply for a LM317
goodfella
I have a 16 Volt, 4 amp wall I wart to use with a LM317 variable power
supply. The LM317 can only handle 1.5 amps, but the circuits that I
will be testing are rated at less than .5 amps. Will the 4 amp
overdrive the LM317 even though I will be using less than an amp?
Rheilly Phoull
YUP !!
Rheilly P
(Dont forget to read books)
Dave, I can't do that
Er, I don't know much about electronics, but isn't current the actual
current being drawn and not necessarily the current that is
available ?
RP would be correct only if the device being powered suddenly drew
more than 1.5A.
Since you are only drawing 0.5A I can't see any problem, however
depending on what you are testing there might be an inrush that could
exceed 1.5A and then the 4A would come into play. A DC motor comes to
mind where at start up current for a fraction of a second can be many
times the run current.
I would think you could use a current limiting resistor in the 4A line
and keep your hands warm this Winter. <g>
I am NOT an expert on this so I suggest you wait for more definitive
answers.
Ted Pavlic
You will have no problem using the 16V wall wart with the LM317. The
current rating on the wall wart tells you want it is CAPABLE of. In
other words, it tells you the maximum power output of the device. In
your case, you'll never need that much. Of course, the LM317 will draw
a SMALL amount of extra power, and so you want a power supply that can
provide GREATER than 0.5A. So you're in good shape with your supply
and your IC.
*) On a related note, it is easy to increase the current carrying
ability of the LM317. If you look at the application examples at the
end of the datasheet, you'll see how you can add external pass
transistors around the LM317. As the LM317 draws more current, it will
signal to the external power transistors that they should provide that
current. So the LM317 becomes a control circuit driving pass
transistors that actually carry most of the current.
*) On another related note, if you look at the LM317 schematic, you'll
find that internally it uses a Darlington pair as a set of pass
transistors that do exactly the same as what I just mentioned. It has
a bandgap reference to hold the 1.25V, and that reference drives a
buffer which drives the base of the internal pass transistor which
delivers all of the power to the output.
--Ted
Robert Monsen
No, it isn't a problem. The LM317 will limit the current.
Regards,
Bob Monsen
goodfella
A great big THANK YOU to all of you who answered. I have always had a
passion for electronics, but not the education. Most of the things
that I have learned have been from generous people such as yourselves
on the net and from looking at schematics. Thanks again.
Rich Grise
supply. The LM317 can only handle 1.5 amps, but the circuits that I will
be testing are rated at less than .5 amps. Will the 4 amp overdrive the
LM317 even though I will be using less than an amp? Thanks
Not a problem. The load only takes what it needs - in this case, the
"extra" 3.5 amps are sort of "in reserve".
http://en.wikipedia.org/wiki/Ohm's_law
Do be careful that at low currents, the wall wart's output might want to
increase beyond the allowed input V of the regulator; some wall warts
have poor regulation.
Have Fun!
Rich
Jamie
No.
The amp rating is what you are able to connect to the supply before
it damages the supply.
Voltage is the factor when being concerned about the connected device
how ever, for safety matters and learning etc..., I have found it
cheaper when working with youngsters getting into the field to use a
series incandescent lamp rated for the supply or connected device in the
event of a direct short. The lamp will illuminate at full brightness to
indicate this condition and create a high resistance in the circuit
there by protecting the components.. This also impresses the little kiddies
Of course, one could always use a selectable current regulated supply :)
http://webpages.charter.net/jamie_5"
Jamie
John said:
The current rating of the load, don't you mean?
And when the circuit is operating perfectly, the series connected lamp
will be dim, no matter what the load?
That may be true, but I'm sure that doesn't impress the rest of us
grown-ups who aren't interested in impressing little kiddies.
Me, at least, since I don't represent the rest of "us".
ha, A lot more than you obviously know about me..
I'm sorry you have the wrong impression of me John. I always placed you
above most others here when it came to judgment calls how ever, in this
case, maybe I am the one that made an error in judgment?
If i'm correct in this assumption, please place me in your ignore list
because I don't need to see any disgruntle users here on account of me.
Have a nice day if you can stand your self.
Ross Herbert
:I have a 16 Volt, 4 amp wall I wart to use with a LM317 variable power
:supply. The LM317 can only handle 1.5 amps, but the circuits that I
:will be testing are rated at less than .5 amps. Will the 4 amp
:eek:verdrive the LM317 even though I will be using less than an amp?
:Thanks
NO!
The current required by the load device is all that will be drawn from any of
the preceding power supply units even if those units have very high current
output capability.
As an example, a telephone exchange battery has current capability in the
thousands of amps range yet the small electronic devices being driven by that
supply don't get fried.
neon
Oct 21, 2006
1,325
Why stop with 4 amps? THE POWER GRID can supply giga watts and some how it is safe to run your house power requirements. the power is determined by the load not by the avalable source
