Power Supply from TODD Products Corp.
U
Uwe Hercksen
i have here a defect power supply from TODD Products Corp. Brentwood,
N.Y. Model MDT-164-2415R
I would like to get some information about it, at least the output
voltages and currents. Are there replacement types from other companies?
Thanks a lot and bye
Joerg
Uwe said:
Todd Products has been acquired by SL Power about ten years ago:
http://www.slpower.com/
Their European outfit is in the UK and you can contact them about that
power supply. Since they also carry the Ault and Condor brands they
should be able to suggest an alternative power supply:
euinfo <at> slpower.com
If you get stuck send me a PM ("reply-to" address works), I know a good
contact person at SL/Condor. But I think it's best to find out what they
can supply in Europe, with power supplies that is sometimes restricted
because of RoHS and all that.
Joerg
Uwe said:
thank you, the best match there is the model MDT-164-2412R, but I got
MDT-164-2415R. I guess there is an output with +15 V instead of +12 V,
but what about the -12 V, is it -15 V or -12 V?
Probably -12V. However, many Condor supplies can be adjusted between 12V
and 15V but you might have to crack through some sealing lacquer on a
trimpot. Sometimes a way to find out is to measure and compare the
resistors across the output because those set the feedback.
Best to send an email to them or call if you want to be sure.
