power supply Pace Sky Digibox 2600
stevyb
Jun 14, 2023
I have a Pace Sky Digibox 2600 satellite receiver, but the power supply has stopped working (no longer receiving power).
Is there a possibilty to repair it or where can I find spare parts to fix it ?
Possibly a blown fuse that needs to be replaced?
dave9
Mar 5, 2017
1,191
What is the evidence of no longer receiving power?
You'd pick a spot and trace backwards along the power path, identify faulty component, identify the type of component (suitable replacement candidates) and swap it in. Parts may be available at electronics suppliers, which ones depending on your geographic location. In the US, Digikey, Mouser, and others.
Yes it is possible it has a blown fuse that needs replaced, but very likely the fuse just did its job and you must first find and repair the fault that caused the fuse to blow.
Is this equipment you own or the property of the satellite tv service? If the latter, they should replace it.
dave9
Mar 5, 2017
1,191
Something is not working with the image attachment view counter. I click/viewed all three images but the counter still shows "Views: 0"... after refreshing the page too.
kellys_eye
Jun 25, 2010
6,512
Many common issue sat receivers have known SMPS issues and there are (or were anyway) kits of parts to replace the 'usual suspects' that were know to fail. Google may be your friend.
Ta dah..... https://www.donberg.co.uk/descript/p/pace_kit_11.htm
Edit - oops, that the 2200 but it may be similar??? That was my first foray though - could be more results out there.
Are you familiar with mains voltage dangers , working with electronics, have a 1/2 decent multimeter....??
