Power to a PC104 bus
Marco Trapanese
I need to power a PC104 board with +5V and +12V.
I'd like to provide the voltages directly through the bus instead of the
connector on the board's edge.
I'm talking about an Advantec PCM3362.
I'm going to connect GND, +5V and +12V to all pins with that name.
Any problems?
Marco
Sjouke Burry
Marco said:
Any problems?
Marco
That depends. Some pc104 cards have an onboard swithching supply,
which might complicate things somewhat.
I know,because I had one where that voltage was somewhat low.
The harddisk did not spin up.
In this particular case, connecting 5volt all over the place solved
that problem.
But dont assume that the internal 5 volt is directly connected
to the supply connector.
Only your ohmmeter can make that known.
That one was a Microspace MSM-P5SEN / SEV
with a pentium5 chip
Marco Trapanese
Ok, so if I check that +5V and +12V are routed directly from the ATX
power-in connector to the PC104 bus I may supply the board from there.
Otherwise I will use the external connector.
Marco
Sjouke Burry
Marco
Use both. The supplypoints scattered around the print
might not be able to carry much current(thin board traces).
What I did was connect those points to the power-in pins
on the board, and then use that one only.
