Slipnfall
- Jan 1, 1970
- 0
I built a PCB around a design example in the Exar 2206 technical
document. I followed closely to the 'test' circuit, but am unable to
get a triangle wave output. I have of course checked connections and
swapped ICs. My SYNC and Sine out work properly. However when I open
the connection from pin 13 to 14, I should get a triangle(13 and 14
are the THD adj pins). When I open the pin, I get the *same* output,
no jitter, no lower Vpk-pk, nothing different. Any suggestions? When
jumpered or unjumpered, I can view a ramp signal on those pins.
Oh and one quick note - why can't one adjust the square/sync output
for duty cycle?? If this is indeed a Sq/Sin/Tri generator, all three
should be adjustable for d/s. I have used the MAX038 before and it
seemed more feature robust.
Thanks in advance,
-Jamie
Thanks in advance,
-Jamie
