Pwm of regulated output.
sureshot
Jul 7, 2012
234
I've never tried this, so just some advise if anyone can help. Can I pwm a smps using a pwm unit to control the smps voltage for DC motor control. All is 12 volts. Smps is a converted server psu, the pwm unit has a 2.5 - 35 volt input, load on the modual is 6.5 Amps maximum. Would the pwm unit cause issues with the smps. Thanks any help appreciated.
14,317
sureshot
Jul 7, 2012
234
Thank you Harald. I was looking to control the final 12 volt out put of a converted server psu. Putting the smps regulated voltage into the unit in the picture. It would be a model railway DC controller I would build with reverse toggle switch, making use of the few converted server power supply's I already have. I wandered if the server smps might not like this type of voltage attenuation.
14,317
I think I understand your original post now better.
A computer power supply "sees" a lot of switching noise from the regulators on the mainboard, graphics card etc. So it is perfectly suited to drive a pwm controller as you show.
