question about Low Pass Filter
audioguru2
Apr 6, 2004
12,026
The 4.7nF capacitor creates a lowpass filter with the unknown value of the source resistance.
The 10k resistor and 6.8nF capacitor create another lowpass filter.
If the cutoff frequency of both filters is the same then their total is -6dB because each filter is -3dB.
walid1
Jun 27, 2004
749
If the cutoff frequency of both filters is  not the same? is it sitll -6dB
thanks
audioguru2
Apr 6, 2004
12,026
If the cutoff frequency of both filters is  not the same is it sitll -6dB?
No.
You need to calculate the amount of attenuation. One filter might pass the cutoff frequency of the other filter then the attenuation is only -3dB.
Kevin Weddle
Feb 23, 2004
1,620
Phase shift oscillators produce 180 degrees phase shift using cascaded RC stages. Maybe the components are chosen so that each stage is independent of the other and reduces the loading effect, which would keep the phase shift at 90 degrees at best.
