Jim Thompson wrote...
Well, then surely you'll want viable Spice MOSFET models, because
you'll be using the FETs throughout their useful linear range, and
the output-stage crossover region is critical.
Sadly most standard Spice library VMOS models simply don't do the
subthreshold linear region. For example, see the 10-decade plots
on page 123 of our book. A jellybean 2n7000 is rather similar to
the VN01 that we show in figure 3.14, and certainly a proper Spice
model should be able to make that plot. But I'd be surprised if
your standard Spice libraries work properly below say 5 to 20mA,
which is not that far below the FET's maximum current. Keep in
mind that linear power FET circuitry always operates well below
the maximum rated FET switching current, to keep power dissipation
junction heating under control.
The bottom line is you'll have to start your FET-amplifier design
exercise by designing some decent FET models. Let us know what you
come up with.
Win, Here's a bunch of models. Which would you recommend?
Anasoft-1:
..SUBCKT 2N7000/PLP_XN _ssi_pin0_1 _ssi_pin1_2 _ssi_pin2_3
Cgs 2 3 12.3E-12
V_ssi_pin2 _ssi_pin2_3 3 0
V_ssi_pin1 _ssi_pin1_2 2 0
V_ssi_pin0 _ssi_pin0_1 1 0
Cgd1 2 4 27.4E-12
Cgd2 1 4 6E-12
M1 1 2 3 3 MOST1
M2 4 2 1 3 MOST2
D1 3 1 Dbody
..MODEL MOST1 NMOS(Level=3 Kp=20.78u W=9.7m L=2u Rs=20m Vto=2 Rd=1.186)
..MODEL MOST2 NMOS(VTO=-4.73 Kp=20.78u W=9.7m L=2u Rs=20m)
..MODEL Dbody D(Is=125f N=1.023 Rs=1.281 Ikf=18.01 Cjo=46.3p M=.3423
+ Vj=.4519 Bv=60 Ibv=10u Tt=161.6n)
..ENDS
Anasoft-2:
..SUBCKT 2N7000_XN _ssi_pin0_3 _ssi_pin1_4 _ssi_pin2_5
* Nodes D G S
V_ssi_pin2 _ssi_pin2_5 5 0
V_ssi_pin1 _ssi_pin1_4 4 0
V_ssi_pin0 _ssi_pin0_3 3 0
M1 3 2 5 5 MOD1
RG 4 2 343
RL 3 5 6E6
C1 2 5 23.5P
C2 3 2 4.5P
D1 5 3 DIODE1
..MODEL MOD1 NMOS VTO=2.474 RS=1.68 RD=0.0 IS=1E-15 KP=0.296
+CBD=53.5P PB=1 LAMBDA=267E-6
..MODEL DIODE1 D IS=1.254E-13 N=1.0207 RS=0.222
..ENDS 2N7000
Supertex
..MODEL 2N7000 NMOS (LEVEL=3 RS=0.205 NSUB=1.0E15
+DELTA=0.1 KAPPA=0.0506 TPG=1 CGDO=3.1716E-9
+RD=0.239 VTO=1.000 VMAX=1.0E7 ETA=0.0223089
+NFS=6.6E10 TOX=1.0E-7 LD=1.698E-9 UO=862.425
+XJ=6.4666E-7 THETA=1.0E-5 CGSO=9.09E-9 L=2.5E-6
+W=0.8E-2)
..ENDS
Philips:
..SUBCKT 2N7000/PLP 1 2 3
Cgs 2 3 12.3E-12
Cgd1 2 4 27.4E-12
Cgd2 1 4 6E-12
M1 1 2 3 3 MOST1
M2 4 2 1 3 MOST2
D1 3 1 Dbody
..ENDS
Ancient MicroSim:
..model M2n7000 NMOS(Level=3 Gamma=0 Delta=0 Eta=0 Theta=0 Kappa=0.2
+ Vmax=0 Xj=0 Tox=2u Uo=600 Phi=.6 Kp=1.073u W=.12 L=2u Rs=20m
+ Vto=1.73 Rd=.5489 Rds=48MEG Cgso=73.61p Cgdo=6.487p Cbd=74.46p Mj=.5
+ Pb=.8 Fc=.5 Rg=546.2 Is=10f N=1 Rb=1m)
Zetex:
..SUBCKT M2N7000/ZTX 3 4 5
* Nodes D G S
M1 3 2 5 5 MOD1
RG 4 2 343
RL 3 5 6E6
D1 5 3 DIODE1
+CGSO=23.5P CGDO=4.5P CBD=53.5P PB=1 LAMBDA=267E-6
..ENDS
...Jim Thompson
