Questions about equivalents of audio/video and digital/analog.
AnthonyR.
Radium said:
Radium wrote:
Other than the microphone [obviously], why does there need to be any
moving parts? If a digital audio device can play audio back without
any moving parts, why can't an analog audio device be designed to do
the same?
Describe a motion-free process of recording and playing back. Cutting
grooves on a disk or magnetizing a moving tape both involve motion.
The iPod is motion-free yet it's still able to record and playback.
Those Nintendo Entertainment System cartridges were able to playback
without any motion.
The device below is *not* analog. It uses sampling so its digital:
http://www.winbond-usa.com/mambo/content/view/36/140/
I'm curious to why there are no purely-analog devices which can
record, store, and playback electric audio signals [AC currents at
least 20 Hz but no more than 20,000 Hz] without having moving parts.
Most of those voice recorders that use chips [i.e. solid-state] are
digital. Analog voice recorders, OTOH, use cassettes [an example of
"moving parts"].
It's this simple: nobody has invented a way. I doubt than anyone ever
will. If you know how, communicate with me privately.
I don't know how but I guessing that it involves the analog equivalent
of Flash RAM [if re-writing is desired] or the analog equivalent of
Masked-ROM [if permanent storage is desired].
I suspect the simple answer is space required. For example you needed a
large reel to reel tape to fit a song, but an iPod uses digital audio
(compressed) so it can fit so many more 1's and 0's onto the same size
magnetic tape that would have only held a little actual analog signal. See?
So if someone did make a solid state analog recorder it probably require too
many memory chips to be practical.
I don't know specs but 8mb that hold tons of music on an iPod probably only
hold a few seconds of actual analog frequency data.
IMHO
AnthonyR.
glen herrmannsfeldt
Don Bowey wrote:
(snip)
Your reply is incomplete.
* "ISDN is Integrated Services Digital Network." Right
* "It is a digital signal in all respects...." Right
* "...using what is called 2B1Q encoding on a customer Basic Rate Interface
loop. That is 2 Binary 1 Quaternary meaning there are two binary bits
encoded in each symbol using 4 possible voltage levels." Incomplete,
therefore wrong.
Those voltage levels go through analog electronics on the way
to the other end. Hopefully the other end detects the appropriate
voltage levels at the right time. It is voltage and current, not
bits, that travel down the wire.
There is also a Primary Rate ISDN, which is a DS1 rate and which uses the
AMI line code, modified by B8ZS. One end of a Primary Rate channel may be in
a Central Office or both ends may be at a customer premises.
On its way to a V.90 modem the signal originates on an ISDN channel,
goes through one D/A converter, and then on to the V.90 modem.
The modem can synchronously decode the voltages and figure out which
bits went into the ISDN line. That process doesn't work if there are
more than one D/A conversions on the line.
-- glen
Jerry Avins
too many memory chips ...
What kind of chips hold analog signals? How do their storage capacities
compare to digital storage?
Jerry
F
Floyd L. Davidson
Bob Myers said:
The definitions according to yourself and your
selected "authorities"? Yet again? How about some
reasoning, instead, for a change?
Every authority uses the same definitions. I've shown
you a list of URL's where, if you had looked, you would
have found exactly the same definition from each
different source.
I note that even though you deny it and claim there are
other definitions, you can't find even one that is
different.
See Shannon, "A Mathematical Theory of Communication,"
section V (27). Have someone help you with the big words,
as needed. When you're finished, find us an example of
a noiseless channel, and demonstrate to us what you're
saying.
You clearly need some help understanding it...
Shannon never used the word "digital," though, and used
the term "bits" simply because that is the commonly-used
unit of information (in ANY system), per information and
Wrong. Shannon didn't use the word "digital" because
it was not a popular term for what he was working with
until *after* he published his work and the study of
digital signals became popular. Nobody except Shannon
was, at that time, thinking in terms of digitizing data,
signals, channels, and everything else. (Okay, not totally
true, as people like Alec Reeves certainly was too...)
Shannon didn't use the work "bit" because of any common
useage! John Tukey, a co-worker of Shannon's at Bell
labs had coined the term "bit" as a short form for
"binary digit", only the year before Shannon first used
it in a 1948 paper. It fit their needs, and later
became popular with others too.
In fact, as the "commonly-used unit of information (in
ANY system)", Claude Shannon was the very *first* person
to use the term! He certainly did not use it because
any common useage, given it had been used only by one
other person and then with a slightly different meaning.
communications theory as it was established at the time
The theory had not been established at the time. It was
Shannon's work that started "Information Theory". While
Hartley and Nyquist had theorized about various things,
and demonstrated certain effects, Claude Shannon was the
one who mathematically *proved* them, thus providing
various theorums for future research.
(and is still in use today). Given that you've admitted to
not being an authority in the field, I wouldn't expect that
One thing that is quit obvious Bob is that I am
significantly more authoritative in the field of
communications than you are. Not that that is saying
much...
you understood that before, so I'm more than happy to
give you this chance to learn. You're welcome.
It would have been nice if you had known what you
were talking about before you again spouted nonsense.
Right - he defined a DISCRETE channel. The only
Yes. You'll remember that the definition of a digital
signal is that it has discrete values. Guess what
Shannon discussed... a channel for transmission of
discrete values. The way we describe that today is
"digital", and Shannon's "discrete channel" is exactly
what a digital channel is.
tie between "discrete" and "digital" appears to exist solely
in your own mind, since your cherished definitions of
That is one of the most hilarious things you've said
in all of this. You flat deny the very reason that
these terms exist, ignore all of their history, and
proclaim yourself an expert. Astounding.
"quantized" also unfortunately neglect to use the word
"digital" at any time. Shannon did NOT refer to either
"digital" or "analog" channels at all.
Of course he didn't. And in 1948 nobody at all was
using those terms to describe a communications channel,
of any kind.
That useage did not become popular until after Shannon's
papers were published. And it should be obvious to
anyone who can read English that the standard
definitions of "digital" an "analog" (as applied to
communications, transmission systems, signals, data,
etc. etc) was selected to precisely match what Shannon's
paper analyzed, and was taken directly from those
papers. (Heh, you wanted evidence and reasoning, well,
there you are. The evidence and the reason.
Wrong again. He discussed the theory of CONTINUOUS
channels, which is how they are consistently referenced in
his paper. In fact, the term "analog/analogue" does not appear
even once in Shannon's paper.
Exactly. The terms digital and analog only became
popular *after* Shannon's paper was published, and as
noted above the standardized definitions are
specifically intended to reference the papers that
Shannon published.
"Analogous" appears a grand
total of six times, each time with the clearly-accepted meaning
of "similar to," as opposed to refering to any specific class of
signals. Similarly, "digital" does not appear at all. Shannon
correctly did not make any distinction between "analog" and
"digital" encoding in terms of information capacity or content,
as his theorems apply to any and all systems.
Nobody else was using those term in that way at the time. It
was *because* of Shannon's work that such terms came into
existance *after* Information Theory became a popular topic
for research.
Or it would have been, had Shannon actually provided
any such definitions. Too bad he didn't.
Too bad you didn't realize the direct connection!
Are you actually so brass as to claim that the "discrete
channel" term that Shannon used is not precisely
describing what we call a "digital channel" today? Or
that his "continuous channel" is not what we call an
"analog channel"? I don't mean something about the
same, close, or relatively... I mean the terms are
*exactly* identical, in all respects.
F
Floyd L. Davidson
Don Bowey said:
Not that I know of. ANSI T1.403 does good. Want to argue with it?
Why would I argue with it. The link provided shows what
ANSI T1.403 says it is. It *does* fit within the
standard DSX-1 pulsemask (which is conveniently
available from just about every manufacturer of test
equipment).
I don't believe so. On the other hand, I inquired to you about the DSX-1
envelope, and you replied with a link to a waveform you drew, which has only
a loose connection to DSX-1. It appears you might be missing something.
You claimed to have worked with transmission
engineering? Did you sweep floors, or what?
F
Floyd L. Davidson
Your reply is incomplete too. There are *many* things
about ISDN that neither of us have mentioned. Of course
neither of us had or have any intention of writing a
book about ISDN.
therefore wrong.
It isn't wrong. I specifically said that I was describing
BRI, and that is because it is the *only* digital format
defined by ISDN.
You just described a DS1, which is *not* defined by
ISDN. Why don't you also describe DS0's, DS2's, DS3's
and what you have for breakfast? They are just as
related to ISDN as is a DS1.
F
Floyd L. Davidson
glen herrmannsfeldt said:
Don Bowey wrote:
(snip)
It is a digital signal, it provides a digital channel,
and it is a digital service.
Voltage is analog, but there is no analog communications
channel involved, no analog data, and no analog service.
It might. It might not.
Note that the "D/A converter" is a CODEC, and in fact is
used as a digital encoder. Input is digital, an do so
is the output (in the direction of the subscriber).
Because of the fact that it is digital, not analog. In
the uplink direction it is an analog signal (v.34
protocol), and can pass through additional codecs.
F
Floyd L. Davidson
Don Bowey said:
Gosh, after all that I guess I should be impressed.......... But........ I'm
not. I wonder why.
Because it is *way* over your head.
F
Floyd L. Davidson
Don Bowey said:
That is nonsense. ISDN has nothing to do with it. Any modern digital
message trunk provides an identical channelizing process.
True. (Aren't you the one who just tried to require a
discription of ISDN to include specs for a DS1 though?
Double standard?)
Same as the Message Network.
Wrong. Nothing restricts anything else in the network
to *only* one set of A-D/D-A conversions. Everything
else has a minimum of one, assuming a digital switch based
line.
What are you calling an ISDN line? The ds1 rate cable pairs? DS3
transport, Sonet, the analog channel that pops out of the terminal
multiplexer?
Good points all!
Don Bowey
And you claimed to have worked in transmission engineering?
Whooosh...
Don't be such an ass.
A question was asked and I replied. If a signal is passed as analog, then
it's analog; not blue analog or green analog, or sort of analog, or like
analog. Calling something quasi-analog brings nothing to the table but
gobbledegook.
Don Bowey
Don Bowey wrote:
(snip)
to the other end.
Analog electronics? Where? The 2B1Q line signals are transported on a cable
pair or higher level multiplexer.
Hopefully my foot. That is the function of the NT1. And what has this got
to do with anything anyhow?
The signal voltage is in the form of the 2B1Q line code, which just happens
to have some bits with none left over.
The NT2 and/or the TA. But so what? Where's the point of your drivel?
Why do you feel it necessary to repeat what is obvious?
Sheesh
Bob Myers
....a lot more argument by vigorous assertion, the repetitive,
monotonous bulk of which has been deleted. However,
a couple of gems that just can't pass by unanswered:
It would not appear to be all that obvious, in that
you seem to be the only one here arguing your particular
definitions - against fair number of people, including more
than one person who IS clearly a recognized expert in
the field.
Wrong - YOU have asserted this repeatedly, and
yet you continue to offer as "evidence" for this a
definition that simply says that "quantized" signals
have "discrete values," with no mention of the word
digital at all outside of your own continued assertions.
Well, to coin a phrase...DUH.
Having to resort to out-and-out falsehoods, now? Please
show any point in this discussion where I have "proclaimed
myself an expert." I would hardly refer to your behavior
here as "astounding," though. Pitiful, perhaps.
Bob M.
Don Bowey
equipment).
No, but I was a member of ANSI T1 Working Groups T1C1 and T1E1 and helped
write ANSI T1.403 and other Standards.
To phrase it in a technical language you MIGHT understand, your mind is an
abysmal mess, and your behavior sucks. You enjoy the comfort of your
ignorance and I'm certain this is how you will remain.
Don Bowey
book about ISDN.
defined by ISDN.
As I said before, but using different terms, you are an ignorant boob, and
what's worse is, you're smug about it.
I won't explain the many errors of your post this time, as I know it's a
waste of time.
Don Bowey
I've changed my mind; I am impressed. You have impressed upon me the
knowledge that you are much less than you would like to be.
glen herrmannsfeldt
storage capacities compare to digital storage?
Look at the ISD MicroTAD-16M.
It can store 16 minutes of voice in 3840K memory cells,
and a 4kHz sampling rate.
It claims 100 year retention in the non-volatile memory
cells, with 100,000 record cycles. It sounds like they
use a memory cell similar to flash RAM, but store an analog
voltage in that cell instead of only two states.
-- glen
Richard Dobson
gobbledegook.
I have no idea which of all these posts to reply to (now mainly ad
hominem, which seems sadly inevitable when a bunch of people who don't
know each other go round in digital circles), so I am replying to this
one. With the most profuse apologiees to Marshall McLuhan, the debate
seems to be of this form (multiple-choice):
Digital =
* the medium
* the message
* both the medium and the message
* neither the medium nor the message
(select one - no interpolated choices allowed).
And a question: does time series analysis (e.g. applying the FFT or
wavelet analysis to daily stock price movements etc) employ Digital
Signal Processing, Signal Processing, or Something Else?
Richard Dobson
F
Frank
digital/analog.>,
Digital circles??? Now we're really going off the deep end.
Digital is a series of square waves. I know because I can see them on
my 'scope. Think of TTL.
"Digital circles" is a contradiction in terms. We can't communicate
effectively if we don't all use the same lingo - with the same
meanings attached to each key term.
It is a well-known and well-documented fact that a digitally sampled
circle, regardless of the sampling rate, *cannot* be converted back
into a perfect analog circle. The mathematical proof of this was
presented at a meeting of the Royal Society in 1681. Look it up.
What's needed in this thread is less science fiction fantasy and more
real hard science.
timepixdc
It would appear that you disagree with your own statement since further
down you write,
What part of "real-world" (as opposed to "imaginary")
in the above did you fail to comprehend?[/QUOTE]
Before something can be developed it has to be imagined.
Edison? Great imagination. You? Maybe not so much.
From a recent (London) Daily Telegraph:
"A pair of German physicists claim to have broken the speed of light -
an achievement that would undermine our entire understanding of space
and time.
According to Einstein's special theory of relativity, it would require
an infinite amount of energy to propel an object at more than 186,000
miles per second.
However, Dr Gunter Nimtz and Dr Alfons Stahlhofen, of the University of
Koblenz, say they may have breached a key tenet of that theory.
The pair say they have conducted an experiment in which microwave
photons - energetic packets of light - travelled "instantaneously"
between a pair of prisms that had been moved up to 3ft apart.
Being able to travel faster than the speed of light would lead to a wide
variety of bizarre consequences."
Your reliance on the "theoretically impossible" would have stopped such
research before it started. You might even be the last person around
that believes in phlogiston. Hard to tell.
X-no archive
