Bob Myers
- Jan 1, 1970
- 0
Randy Yates said:It isn't reaonable to you. Don't publish opinion as fact.
OK, it's not reasonable to ME, either, if you're impressed
by taking a vote on this sort of thing.
The problem with the definition that you and Floyd seem to
want to use is that it leads to several problems in both
theory and practice, in addition to the fact that there are
numerous counter-examples one can point to.
"Reasonable" would seem (at least to me) to mean that you
can justify your definition *through reason*, which Don has
done. Simply pointing to a published work, including a
standard, as a reference to support your definition is what's
called an "argument from authority," and it has exactly zero
weight in light of an opposing argument based on evidence
and logic. However, if you like, I can also point to several
references which support the definition that Don and I (and
I believe others) are proposing. You might claim the list to
be invalid, however, since it would contain works that I
myself wrote for publication. Which is, of course, the whole
point - simply having your statements published does NOT
make them any more or less correct; the deciding factor is
whether or not they can be shown to be true through evidence
and logic.
Bob M.
You haven't looked very far. Here is an example (a power calculation):
The question was flawed to being with, though - "DSP" stands
for "DIGITAL signal processing," which by definition could
not have been done on information that was simply "sampled
in time." Such information would also have to be digitally encoded
in order to be subject to "DSP.:
I won't argue that the current usage isn't good nomenclature, but that's
the way historically things have developed.
A common misuse or misunderstanding does not become
less so merely because it IS common.
Bob M.
