Rating of the Relay
Sravanthi
Feb 4, 2015
72
Hi...
Is there any dis advantage of selecting a electromagnetic relay which is having higher contact rating of our application.
Suppose if I my application needs 1A current carrying contact , if I am selecting 16A contact rated relay. Does is there any disadvantage.
Please reply me..
Thank you.
it might cost more
the coil may require a higher current
it may be larger
for very low current applications (lower than you're talking about) you may not have sufficient current to wet the contacts.
Sravanthi
Feb 4, 2015
72
it might cost more
it may be larger
Can you explain last point: very low current applications (lower than you're talking about) you may not have sufficient current to wet the contacts.
Related to failure rate of the relay will there be any change.
AnalogKid
Jun 10, 2015
3,058
For some applications such as AC power to motors, the contacts arc as they separate. This arc burns off oxidation that would eventually form an insulating barrier over the contacts. Depending on the contact material, there can be a similar issue with low current DC signals. This is why many panel switches are available with silver contacts for 10 A AC, or gold contacts for 0.1 A DC. Of course the actual ratings vary from one manufacturer to the next, but those are the basics.
ak
Sravanthi
Feb 4, 2015
72
ak
Thank you for basic information.
What is the dis advantage of using a higher rated contact for low current application. Its a DC contact relay.
Can you give me the basic of bifurcated contacts. Is DPDT and bifurcated contacts are same???
Why do you want to know this. It's starting to sound like homework.
Also, simply googling "wetting contacts" would have given you multiple links to you previous question.
Have you tried google for your questions?
