Receiving a radio signal...
Externet
Aug 24, 2009
944
Hi.
When a radio receiver is tuned to say, 100 MHz; its local oscillator is at say 110.7MHz, the mixer stage produces a 10.7MHz intermediate frequency for later demodulation.
If the broadcast ceases to emit, goes off the air;
Or, shifting tuning to a blank unoccupied frequency;
Or, shorting to ground the antenna input;
is 10.7MHz still present at the mixer output ?
And, do you know of an IC that can be used to detect the presence of 10.7 MHz ?
14,487
the 10.7 IF is only there when the RF and the LO are mixed
if either is missing then there is no IF out
a google search would have answered that for you.
there are many IF IC's that have a 10.MHz input eg
MC3357 --- NBFM dual conversion IF, 10.7MHz In, Audio out
MC3359 --- NBFM dual conversion IF, 10.7MHz In, Audio out, less external components than 3357 and addition IF limiter stage
MC3361 --- NBFM dual conversion IF, 2-8V supply, up to 60MHz I/P
MC3362 --- NBFM dual conversion IF, 2-6V supply, usable with PLL, carrier detect indicator, up to 200 MHz I/P
just some of the many in my own collection
duke37
Jan 9, 2011
5,364
Most FM radios have a muting control to turn off the sound if no signal is being received. The gain of FM recievers is very high and if there is no signal then detected noise produces a rushing noise.
Externet
Aug 24, 2009
944
Thanks, gentlemen.
Dave : I meant knowing if 10.7MHz is present. No audio detection desired. To work on silent unmodulated signals. My searches found complete receivers as your suggested chips.
Intention is to know if a carrier is present, on a receiver chip that does not have tuning indicator feature. Perhaps using a section of some other chip that could be added to an existing receiver.
Will explore portions of the MC3362, for presence of 10.7MHz telling there is carrier.
Audioguru
Sep 24, 2016
3,656
I agree that the 10.7MHz from the mixer will never be zero. It will have either signal or noise. Maybe its muting circuit detects the amplitude fluctuations of the noise?
14,487
Thanks, gentlemen.
As I stated before
If either the LO signal or the RF signal is absent, there will be NO 10.7MHz IF signal generated (in the mixer) that then goes to the IF input pin of the IF IC
