Receiving Pulse-Code Modulation on AM radio?
Radium
Hi:
Hypothetical situation: a PCM audio signal [24-bit and monoaural] is
transmitted through an analog 150 Khz AM carrier, an AM receiver on the
other end [tuned to 150 Khz] picks up the signal, and the reciever is
attached to a device that can recieve, process, and decode the PCM
audio back to analog and then send it to a loudspeaker. However -- in
this theoretical situation -- the environment is filled with magnetic
interference that affects all AM stations.
My question: Will the received PCM audio signal remain noticeably
"clean" to the listener or will he/she notice the magnetic disruptions
affecting the audio?
I ask because I think -- but definitely don't know -- that because the
received signal is digital, it is less likely that the static would
cause noticeable auditory disruptions when compared to analog. Do I
guess correct?
Radium
John Larkin
Hi:
Won't work. The data bit rate (for 44 KHz sampling) is 1.05 MHz, too
much to put on a 150 KHz AM carrier, at least without insanely exotic
modulation tricks.
John
Radium
John said:
Hi:
modulation tricks.
John
Just what are these "insanely exotic modulation tricks"?
Radium
John said:
Hi:
modulation tricks.
John
What is we use a 3 MHz AM carrier, instead?
Tim Williams
Think data error.
Tim
Radium
Think data error.
Could heterodynes [often heard as frightening high-pitched tones on
analog AM radio] cause data errors [or any other disruptions] in a
digital device receiving PCM signals on an AM station?
Eeyore
Radium said:
John said:
Hi:
modulation tricks.
John
They're more insane even than you !
Graham
John Larkin
John said:
Hi:
modulation tricks.
John
You'd have to research communications theory. Google "information
theory" and "Shannon capacity" to start.
John
