reed switch and tiny motor NO arduino
Crafts4Me
Feb 10, 2022
175
can i attcah a reed switch to a small motor that doesnot need an arduino. when my train will ride over the switch it will cause a gate to open
kellys_eye
Jun 25, 2010
6,512
Depends on the reed switch and the motor being used. The motor will draw a certain current and the reed switch contacts must be able to carry that current. Typically, reed switches can carry around 1A maximum therefore your motor should be rated UNDER 1A. You can, of course, increase this maximum current by using the reed switch to activate a relay and the relay contact to activate the motor - in which case there is no practical limitation on the current.
14,317
In the simple scenario the reed contact will close only momentarily while the magnet under the train passes over the contact. It will open as soon as the magnet has passed the contact. This will result in a short pulse only, the duration of which will depend on the speed of the train (slow train, long duration and vice versa). If that is enough for the gate to open you're o.k.
If not, you may need a timer module (example) to generate a pulse long enough to open the gate, The timer would be triggered by the short pulse from the reed contact.
darina99611
Aug 9, 2022
thank you for the explanation. My husband has faced the same problem
