Relay That Toggles On & Off With No Hold Current
XJohnDoe001x
Dec 25, 2014
17
Friends, are there relays that toggles on and off that uses no power to hold either position, that only uses current to make the change??
I want to hide small, flat surface mount momentary buttons underneath the upholstery for secret functions.
I am a knuube of sorts I took a one year Basic Electronics course thirty one years ago and never did anything with it. I understand what the components do but I don't know the circuitry of any particular field i.e. audio, radio or Chronometric Particle Emitter.
Minder
Apr 24, 2015
3,561
The magnetic pulse latching relays have memory, needs a reverse DC pulse to unlatch.
M.
Robert_fay
Jun 15, 2017
124
I would think there may be an easy way to do something like this with hall effects/reed switch. You would be able to momentarily turn something on or off with only a magnet. Might be a solution depending on the rest of the circuit?
Alec_t
Jul 7, 2015
3,818
I bet the relay module shown requires continuous current to keep it in one of its two states :(.
XJohnDoe001x
Dec 25, 2014
17
I will not bet against you. The datasheet of the relay on this PCB gives no indication of being a latched type.
As recommended in post #3 by Minder look for a latching relay.
Thank you for your reply, I have looked at Latching relays but I don't have internet get tired sitting on the corner using the Hotspot, my internet connection should be up by the end of the week, then I can do some real research
