Relay with 50KHz, 1.9A rms?
duke37
Jan 9, 2011
5,364
You mean kHz not KHz !
The relay should stand the current but you do not say what voltage it is switching.
Assuming the voltage is within limits for the relay, and that the load is not inductive, you shouldn't have a problem (OK, capacitive is an issue too).
14,484
no, its just a standard relay coil
no diode built in
did something make you think that it was polarity consious ?
14,484
eem2am
GRRRRR
stop starting new threads on the same topic!!
now merged
eem2am
Aug 3, 2009
429
If i drive the coil of the 12V version of this relay from 24V, then is all i have to do is put a 1200R resistor in series with the relay's coil?
A 12V zener is probably better.
eem2am
Aug 3, 2009
429
Thanks, is that something to do with the L/R timeconstant and getting the relay to "switch"
